THE SCREEN WON'T POWER UP..NO PICTURE OR SOUND.
PANASONIC CT27612U THE SCREEN WILL FLASH ON AND THEN GO OFF. IS THIS FIX-ABLE AND IS IT WORTH IT TO FIX IT. WHAT DO YOU THINK. NANA C. TCLARKFARMS@SRCACCESS.NET
    Genius:
  • Televison & ... Master
  • 1,689 Answers
From your description it seems that when the high voltage comes up there is a fault detected by the uPC, and the power supply is put in to the protect mode. This can be from many problems such as the flyback transformer failing, or a defective component(s) in the secondary supply from the flyback, or the CRT itself having a failure.
On many of these sets, there is an HV multiplier that is part of the flyback assembly. This HV multiplier is usually where the fault occures more so than the internal windings of the flyback. But, they come as one molded assembly.
Most often, I have seen this fault from the flyback transformer or the CRT.
This has nothing to do with anything you connected to the set. This problem would have occured anyways.
Jerry G.
Posted on Apr 19, 2008
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
I have a wd-65738 TV . Heard pop no picture with
That pop was probably a capacitor blowing up in the power supply. Could be another power component too. Get an estimate from a TV repair shop first to see if it's worth fixing or flat screen TV time.
Sep 07, 2014 | Televison & Video
Picture won't display. YPbPr is flashing on screen
go to settings and select the computer mode instead of YPbPr
the image from the computer will be seen
Dec 16, 2012 | Panasonic PT-AE700U Multimedia Projector
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
When turning on my panasonic cinemavision tv, it makes a click sound then the power button light flashes red three times, no picture comes on the screen, any ideas what should be done?
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Feb 18, 2009 | Toshiba TP55H60 55" Rear Projection...
Power button Flashes, tv doesn't turn on
Buy a new one , not worth fixing. I have the same tv, with the same problem . It's getting old now and the price of a new one . It might cost $ 400-500 big ones to fix it . Thats half the price of a new flat screen , cheap model mind you . But I still think it's not worth it .
Nov 28, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Nov 02, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Black pictures
it is worth to repair instead getting new, contact your panasonic service center
Oct 27, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
