Intuit QuickBooks Simple Start Edition (283063) for PC Logo
Posted on Jul 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get an error when I'm closing Quickbooks Simple Start, The instruction at "0x56461f49" referenced memory at "0x036c4360". The memory could not be "read". Do you know what this means and how to fix it?
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Nov 27, 2010
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
11018
Points
103
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
  • milsheetmeta Dec 30, 2010
    When I shut down my computeer it reloaded the update and the same problem persisted
2answers
How to fix QuickBooks Error Code 3371 and status 11118?
QuickBooks Error Code 3371 and status 11118 can occur when there is a problem with the QuickBooks license data or when the data is damaged. To fix this error, you can try the following steps:
  1. Repair or reinstall Microsoft .NET Framework: QuickBooks requires Microsoft .NET Framework to run, and this error can sometimes be caused by a problem with .NET Framework. Try repairing or reinstalling .NET Framework to fix the error.
  2. Repair or reinstall QuickBooks: If repairing or reinstalling .NET Framework does not fix the error, try repairing or reinstalling QuickBooks.
  3. Reset the EntitlementDataStore.ecml file: This file stores your QuickBooks license information, and the error can sometimes be caused by a problem with this file. To reset the file, follow these steps:
  • Close QuickBooks
  • Press the Windows + R keys on your keyboard to open the Run dialog box.
  • Type "C:\ProgramData\Intuit\Entitlement Client\v8" (without quotes) in the Run dialog box and press Enter.
  • Locate the EntitlementDataStore.ecml file and rename it to EntitlementDataStore.old.
  • Reopen QuickBooks and try activating it again.
  1. Contact QuickBooks Support: If none of the above steps fix the error, you may need to contact QuickBooks Support for further assistance. They will be able to help you troubleshoot the issue and find a solution.
I hope this helps! Let me know if you have any other questions
3answers
Intuit Error 15243
Intuit Error 15243
QuickBooks Error 15243 by Dylan on January 27, 2019 in QuickBooks Help 0
QuickBooks Error 15243 Overview QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update. QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly.
Causes of QuickBooks Error 15243
The various causes due to which QuickBooks error code 15243 occurs are mentioned below:
·Incorrect QuickBooks installation
·Intuit QuickBooks File Copy Service (FCS) is damaged
·QuickBooks FCS service is not enabled
·QuickBooks Payroll subscription has ended
·Damage in Company File
·User not logged in as an Administrator
QuickBooks Error 15243 - Intuit FCS Service is Damaged QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application
·Go to the Start button
·Right-click on Computer/This PC
·Choose Manage option
·Go to Services & Application Tab
·Double Click on Services option
·When you see Intuit QuickBooks FCS, click on it
·Click on the General Tab
·Click on Startup
·Choose the Manual option
·Click on apply
·Choose Start & then Ok
·Now, Reopen your QuickBooks as an administrator
·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription.
Resolve QuickBooks Error 15243 in QuickBooks Payroll ·Open QuickBooks
·Go to the Employees option
·Choose My Payroll Service
·Select Manage Service key
·Click on the Edit option
·Verify your Payroll Service key
·Choose the Next option & remove the check for Open Payroll setup- I want to start right now
·Select the finish option
·After the verification, Go to Employees
·Select Get Payroll Updates
·Download Latest Payroll Update for QuickBooks Desktop & Update
Contact QuickBooks Support to Repair QuickBooks Error 15243 If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243.
Common Errors like QuickBooks Error 15243 ·QuickBooks Error 15271
·QuickBooks Error 15215
·QuickBooks Error 15101
·QuickBooks Error 15214
·QuickBooks Error 15203
·QuickBooks Error 15222
·QuickBooks Error 15262
·QuickBooks Error 15102
·QuickBooks Error 15106
2answers
How to Fix QuickBooks Unrecoverable Error?
While opening or working with an application, it is quite common for an error to occur. If you're encountering the QuickBooks unrecoverable error, then you're not alone. This error has been encountered by many QuickBooks users and they have fixed it using simple troubleshooting instructions. Generally, when QuickBooks encounter this issue, you will receive an error code. Follow 3 simple methods given here to fix the error. https://installation-help.com/quickbooks-unrecoverable-error/
1helpful
The instruction at "Ox7752c56c" referenced memory
Hello davidlange, could you describe what you were doing before you got this error message?
Error message on attempt to scan: "Instruction at "0x673328c8" referenced memory at "0x21900668". The memory could not be "read"." need fix.
I must blush to say that I reviewed the error messages more closely and discovered that the solution was with an application, not the scanner. Thanks tremendously for your prompt attention.
2helpful
Problem at start-up
Sounds like you have a bad memory module. Test them one by one to discover the faulty one.
1helpful
3answers
Error message " quickbooks has encountered a problem "
1. Do you have a backup of your quickbooks from before this started happening? If yes, try opening the backed up quickbooks file.
2. Uninstall Quickbooks 2009 completely, then reinstall it and check of updates and install all of them, then try it again.
If the problem persists, please let me know so I can continue to help you. These are the first two things to try and would be the easiest solution.
Thanks for using the FixYa forums!
2helpful
2answers
Windows Error Code
The instruction at "0x77c2a573" referenced memory at "0x00000003".the memory could not be "written".
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
