Question about Canon Office Equipment & Supplies
THE ROLLERS THAT FEED PAPER ARE MAKING A LOUD SQUEAKING NOISE. THERE IS NO PAPER JAMMED OR STUCK ANYWHERE. ANYONE ELSE HAVE THIS PROBLEM? AND HOW TO FIX IT.
  • 1,219 Answers
Wich model of copier or printer you are refering too?
It could be that some clutch or gear is rusted, or some bushings are dirty...
Posted on Jul 10, 2010
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 11, 2009 | Canon Office Equipment & Supplies
It keeps saying remove jammed paper but there is no jammed paper anywhere i have done everything except take it apart
Please try these steps if you have already tried these steps then its hardware failure on your printer....
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 22, 2009 | Lexmark X2500 All-In-One Printer
Paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Nov 11, 2008 | Ricoh Aficio CL7200 Laser Printer
Paper feed
Hi there.
First of all pull out the paper jam cover - is behind the printer with a clock-like handle. Pull it out and check for any paper or other objects. If U dont see anything try to manualy rotate the black rubber rollers and check for that noise. Locate it and try to describe what you see.
Jun 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
254 people viewed this question
old marine
old marine
