Question about Frigidaire PLHS269ZD Stainless Steel Side by Side Refrigerator
I make ice fine but each time the ice maker is filling up with water to freeze out comes about a tablespoon of water from the water dispenser. When I turn the ice maker off of course the water doesn't come out. While making ice I have to keep a small plastic cup under the water dispenser and empty periodically.
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Posted on Aug 05, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
Ice maker freezing up
The water line to your unit may need to be replaced. Check how fast water comes out of the dispenser. If it's trickling out or takes 30 seconds to fill the glass, you have poor water pressure to the unit and it's causing the fill tube to freeze.
Nov 27, 2013 | Refrigerators
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The icemaker is not filling with water to make ice cubes. The water dispenser woorks fine. Any ideas?
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Mar 21, 2010 | Refrigerators
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
No water going into ice box of icemaker. Motor seems to be working ok. Checked hose not snagged.
Most times that will be the water control valve on the rear of refrigerator and most times they come as a pair or dual one side for water dispenser and other side for the ice maker. You can test to see if the ice maker is defective by turning switch on and fill with tap water. When it freezes and dumps but no water refills the ice maker then the valve for the ice maker side is defective and will need to be replaced as a pair. If you fill ice maker with water and it freezes and then does not dump then most likely the ice maker is defective.Thnks Sea Breeze
Dec 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker does not make ice.
The water dispenser and the ice maker use a different side for each one. The water control valve is most likely the problem. To test the ice maker fill with tap water and let freeze. If the ice dumps then the water valve is the problem. If you need part numbers I will need your model number. Thank you Sea Breeze
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Open Questions:
Frigidaire PLHS269ZD Stainless Steel Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
