Question about Kitchen Ranges
Does my range have a disconnect plug?
I am replacing the element in my smooth top range and can't determine if there is a disconnect plug for the surface element wiring harness. I am following your instructions from a Feb 11 post. I have a Whilrpool GJP85802 range. Please help!
  • smartcookie Apr 21, 2008
    I followed your instructions by disconnecting the terminal lugs, labeling them with masking tape and carefully reconnecting the new element. My cooktop was hinged so I could raised it and prop it open. It worked like a charm! I saved myself the service call and labour charges as well the inconvenience of waiting for service. Thank you for your prompt reply. I am happy to say I did it myself!
  • 5,911 Answers
If there was a disconnect plug it would be located either under the cook top, or inside the console. The plug is generally square white plastic. The illustrated parts breakdown at searspartdirect.com was inconclusive. It did not show any disconnect plug, but it also didn't show the wiring harness either. If there is no disconnect on this model, simply disconnect the terminal lugs at the element you are replacing. Just be sure to write down where they connect to (HINT: a digital camera also comes in handy), and make sure you disconnect the power cord BEFORE opening the appliance. There's still power present with the stove turned off. Good luck and let me know if I can help you further.
Posted on Apr 20, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 21, 2008
    Good for you! Glad I could be of assistance.
Top oven woun't heat up
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Jul 04, 2014 | Whirlpool RBS275PD Electric Single Oven
How do you open the smooth top, on a Maytag range?
There will be 2 or 3 screws under the front edge of the top. Take them out and top will hinge up similar to the older models.
Unplugg the range before touching any wires. There is voltage on the thermal limiter on the element even when the switch is off.
Once you have access to the element you can check for power and continuity just like on an older range.
Post back with any questions. I will see if I have a manual on pdf.
Thanks/Mike
Nov 04, 2007 | Kitchen Ranges
Tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
1. UNPLUG the range before servicing.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
on Apr 05, 2010 | Kitchen Ranges
Tip
This advice explains the steps necessary to replace one of the surface elements on a smooth top electric range.
The cook top will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
on Dec 22, 2009 | Kitchen Ranges
Replaced oven element still not heating up
The bake element
Surface burners
The infinite switch
Feb 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Frigidaire smooth top range. Burners heat, EOC as no power and thebake and broil elements therefore can't be turned on. I ordered and replaced the EOC. I am getting 240 volts from the wa
I'm assuming you're in the US, and the regular power outlets should have 120v AC.
Check your neutral at the power outlet. Between any of the 2 hot wires (your 240v) and neutral there should be about 120v AC.
If the neutral there is ok - check continuity between a white wire in a 6-pin plug on your board and neutral on the range plug.
If all ok there - check continuity between a black wire which connects to "L1" on the board and black wire from the power cord at the terminal block.
Good luck,
Vlad, First Choice Appliance Service in Sacramento, CA
Jul 06, 2012 | Kitchen Ranges
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Sep 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Dec 23, 2007 | GE Spectra JBP84 Electric Kitchen Range
Shattered glass top for Hotpoint range/ how to replace
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Sep 07, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
