I just bought a new printer C7200 All in one Series and am trying to set it up. I have the following message that I cannot get rid of: Incorrect Ink Cartidges The following inc cartridges cannot be used after device initialization and must be replaced. It shows all of the colours.
  • 3,037 Answers
Take it back to the store and get a different one. For some reason some of the printers get this error and HP has no solution that I am aware of to fix this problem.
If the next printer has the same problem, then I will do all I can to help you out, possibly it would be a driver problem then but it's just one of those.
If you want, you can try uninstalling and reinstalling the drivers first but I would just get a different one and see if that resolves the problem first.
Please update me on what you do and I will be here to help all along the way.
Thank you for using Fixya and Good Luck
Posted on Apr 19, 2008
    Genius:
  • 3,422 Answers
HI,
if you know the cartridge is installed correctly and it's a genuine chipped cartridge, disconnect printer, uninstal driver.
Re-install driver and re connect printer, this way you will know it's not a software problem, and the printer may of retired itself.
OR:
If is the correct type of cartridge May be you not put in the correct positions the cartridge, check it.
Goodluck,
Please don't forget to rate the solution
    Brigadier General:
  • 3,614 Answers
May i know the operating system you used in your computer, & we will get back in to your problem..
Thanks
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3382185#Error386
Jan 03, 2010 | HP Office Equipment & Supplies
I have an HP Photosmart C7200 All In One Series. On my previous HP printer, I was able to copy documents and shrink the images. Is this possible on my new Photosmart C7200?
yes it is ,, Once you install the drivers propperly then all the features will be in the toolbar. you can axcessthis tool bar by pressing the copy button on the printer, then you can reduce the image size. Another method is by using the scanner tool bar, aviable in the all programs menu(START / ALL PROGRAMS) once you start the tool bar, simply click copy and folloy the onscreen instructions then set it according to your desire.
Jul 29, 2008 | HP Office Equipment & Supplies
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
I have a Lexmark X3430
the cartidge that you have just refilled is not filled correctly.
May 29, 2009 | Lexmark X2500 All-In-One Printer
HP C7200 All In One Printer
Try this:
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Dec 14, 2008 | HP C7200-69016 Network Adapter
My new HP Photosmart C7200 All-in-One series will not operate when switched on. The lcd shows the numbers 1-5 and will not respond to the set up button.
The control panel facia was removed then replaced ensuring that it clicked firmly in place otherwise it impedes the on/off switch and other control buttons.
Nov 06, 2008 | HP Office Equipment & Supplies
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
jasbo
jasbo
