Question about Frigidaire FAC124 wall/Window Air Conditioner
Unit sounds like water is flushing thru on the inside, but there is no leakage anywhere. it sounds like a babbling brook inside the unit.
It may just be the refrigerant rushing through the system or the condensate water being thrown against the outside coil by the fan blade to evaporate the water, either case is normal
Posted on Jul 10, 2010
My ac unit is leaking inside of RV
Easiest thing to do is to run a plumbing snake thru the drain line. A medium pressure water hose might work as well to flush it.
Jul 31, 2016 | Heating & Cooling
Lefroy Brooks flush valve
Most flush valves are universal, but try to contact manufacturer and see if they can help, or try plumbing supply store (not a home depot)
Jun 21, 2013 | Lefroy Brooks Plumbing
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Leak bubbles out from top vent thru sponge barrier - just wondered why?
I had the same issue before and called Saniflo. They told me that when the pumps are assembled at factory, they use soapy water to test the unit and see if it leaks. By flushing the toilet with plain water only a few times will eventually get rid of the soap residues inside the pump.
Jun 09, 2010 | Saniflo & Saniplus& Macerator Pump
Water leakage inside flush tank
you will need to find out the brand name of your flush/fill valve. some valves merely twist to achieve a new fill level. others work differently. UNLESS, it is the kind with the float ball at the end of a rod. In that case, just bend the rod slightly down if the tank is overflowing.
Apr 20, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
Water trinkling sound
This is normal sound, it is just a condensation buildup inside the machine that is dripping into drip pin than drips outside.
Aug 01, 2009 | Haier ESA306 Air Conditioner
Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Jan 29, 2008 | Heating & Cooling
Frigidaire FAC124 wall/Window Air Conditioner Logo
556 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
