Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung DLP TV repair or replace that is the question!
I have a Samsung DLP rear projecion TV. He is 7 years old. History of symptoms: Occasional high pitched whine on and off for years. Used to shut off and flash "Lamp" now will stay on but there is a very loud screaming/whirring sound that continues for a few moments after the set is turned off. I am trying to differentiate between cleaning/oiling/replacing the fan and replacing the lamp or the color wheel. Any troubleshooting ideas would be greatly appreciated.
  • Samsung Master
  • 8,617 Answers
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Posted on Jul 10, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
My 46" Samsung DLP Rear
It's possible that the DLP chip is going bad. I'm not sure how much it would cost to repair it. If you have the part number you can search for it on ebay and probably find it cheap. I couldn't tell you how much it would cost to have someone repair it, or how to do it. I do know that diagnostics typically cost around 100.
May 04, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on Sansung DLP TV 2.5 years old
probably need a new light engine, contact samsung again get to a supervisor and make a lot of noise!
Aug 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots
Bad news, The Light engine has gone bad.The cost of the light engine is usually over $800.
Do Not Repair. Cut your loses. Always buy an extended warranty on any new electronic gadget, especially a TV. It will pay for itself.
Jul 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on samsung dlp
HI, these are the signs of a failing light engine. you will need to replace this engine soon. these distortions will worsen over time.
Jul 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
406 people viewed this question
Jerry Greenberg
Jerry Greenberg
