Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Turn on tv, makes the normal pop and click sound, red light flashes 3 times and then nothing happens. Try to turn off the tv and the red light flashes 3 times everytime (TV doesn't appear to shut off). leave it alone for a half hour, hit the power and the pop and click sound happen, red light flashes 3 times, repeat problem.
  • mwilson904 Jul 12, 2010
    took a while but we got there and I'm confident the problem was identified correctly (and more importantly what it meant in layman's terms) and tips on how to remedy. Extremely helpful and beneficial. Thank you!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 3 blinks issue in your Sony Wega TV means the lamp cover is not closed properly. To start with open the lamp cover and take the lamp out then check the lamp switch and reseat the lamp & close the cover properly. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
  • 6 more comments
  • mwilson904 Jul 11, 2010
    Can't seem to find the lamp cover. Manual pretty minimum as far as info goes.
  • Rylee Smith
    Rylee Smith Jul 11, 2010
    You are right, I misread the model no#...sorry about the wrong info. 3 blinks in your Sony FD Trinitron WEGA means an issue with the power supply circuit, you'll need to check T603 and R672. The unit will go to standby mode and display 3 blinks due to over voltage.
    I fell that I'm somewhat technical but have no idea how to check T603 and R672 or even what T603 of R627 is/means. Any insight?
  • Rylee Smith
    Rylee Smith Jul 12, 2010
    T603 is a converter transformer and R627 is a resistor, if you want to do the repair yourself then you can check this repair manual however, if you think you dont have
    electrical expertise about
    the internal circuitry of the unit then its always better to contact a professional.
    ok, so I believe these are fuses and i will continue to look on the web but how do you check fuses (where are they located). can't believe how useless this manual is.
  • Rylee Smith
    Please check my previous comment
    Yeah, I posted moments before your response. Got it all, thanks. Now to see if I have the expertise or end up ruining it for good. I love it but it's hell to move around the beast when i see all these 35 lb flat screens. Thanks again!
  • Rylee Smith
    OK :-), Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My tv lost the picture but the sound was working. i then turned the tv off then on. nothing happened. the red light flashes to green then to red with no clicks and or no sounds. i wasnt in the room at the...
I had the "pop" happen to me about a month ago. Sounds like the same symptoms as you list. I searched online to find the most common fix to the the Y Sustain board. You can find this part online for about $150. I have used rivervalleyelectronics.net. Ultimately, I chose not to fix my tv and bought a new one. Before trashing the TV I removed all the boards and have them available for sale if you are interested. I will sell all the boards, including speakers and cooling fans for $150 plus shipping. Contact me if interested.
Sep 28, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Ihave a rca 27v414t. the problem is it won't turn
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Televison & Video
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
