Power switches off immediately after turning TV on then the Power Light continues to blink AMBER....?
  • kliotti Jul 14, 2010
    Very helpful. I think it's time to go to TV shopping again : )
  • 11,800 Answers
It blinks amber because this way it is signalling that the power source of the tv has entered in protected mode - one of the power lines from the source has been overstressed by a faulty part and the source has itself shutdown to prevent further damage. The tv must be opened and tested to identify the faulty part - this is a job for somebody with experience in electronics, preferably a pro. And it will probably be expensive so be prepared for a stiff bill.
Posted on Jul 10, 2010
    Thanks for your helpful reply. FYI - I plugged the tv in again today and this time it
    continues to blink green instead of amber. Obviously something is wrong, so I was just wondering if you think it's worthy of repair or should I just buy another tv...? I got it on sale for only $399 and it's probably even cheaper now. Thanks for taking your time to reply to me. I really do appreciate it...Ken
  • Azrael SRL Jul 14, 2010
    Fixing it would cost you at least $100, even $200. That much money simply isn't worth it. Yes, i think it's time for a new tv.
Vizio m550nv amber light is on but tv will not power on
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Amber Light blinking on power switch
27 mgz oscillator on the back of the main board. Try resoldering it, or replace it.
Dec 10, 2008 | Dell W2607C Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
