Question about Hotpoint Dryers
Not heating up
Hotpoint tumble dryer model No CTD 40 G Not heating up
    President:
  • 2,702 Answers
First thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Posted on Jul 12, 2010
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
Hotpoint dryer model #dlb3400sblwh not heating up
hi u can check see if heater looks good if so more than likley themostat gone just above heater element
Feb 13, 2013 | Hotpoint Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
Tumble drier works but wont heat
Hi can you tell me what make model etc.... I then can tell you what is wrong!
Dec 28, 2008 | Hotpoint Dryers
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Help
stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Aug 07, 2008 | Dryers
Dryers Logo
123 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
