Question about Panasonic Car radio CD CQ-C1110GN CD Player
Got a panasonic cq7203u and got sound out of radio but no sond from ipod or cd. need help
Panasonic SC-HC271 Changing radio without remote
You can change the Radio station by using the button on the top of the stereo system. The double arrows left and right will change the radio station when in "Radio" mode.
Mar 03, 2014 | Panasonic SC-HC271 iPod Dock/CD Player...
I have a zs-s41p boom box that takes an ipod and CD. I'm not getting any sound at all. Radio, ipod or CD player. Help!
Check the back of the unit for possible shorts in the speaker wires, no change! take the boombox to a service centre for a repair estimate.
Aug 13, 2012 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Preplace the charger by another device
Yes it is possible with any cd changer that have RCA jacks behind the radio,
that is your case, you are goin gto install a audio sensing device, when the ipod is on the cd changer will stop,
when the ipod is off the cd changer will play 10 seconds later
this interface is only rca jacks easy to plug behind the radio and you can use any audio source, ipod mp3 sat radio
you can also buy a ipod cable
audio sensing device, it is made for sony, but will work with any rca jacks source, also cd changer must be present all the time, don't remove it
Nov 09, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Connectiong ipod to panasoninc df200u
the df200u is a old unit it can not be done , you can hook up a cd changer to it thats all .. cd changer model cx-dp880
Feb 26, 2009 | Panasonic CQ-DF200U CD Player
Ipod connection -- how does it work with the sound system?
change your system to cd. i have a 2007 and in order to hear my ipod i have to have my radio on cd. hope that helps
Dec 02, 2008 | 2007 Mitsubishi Eclipse Spyder GT...
Make a ipod work on a panasonic cq-vd6505u
Ensure you have this cable (Panasonic Car Audio CA-DC300U iPod Connection Cable for Panasonic Car Stereos) or if you are wanting to put a Ipod with video you will need the CA-VDC300U. The cable plugs directly into the back of the radio or to the CYEM-100U expansion module. Once the cable is plugged in and the radio is installed (if you hooked the cable up to the back of the radio) turn your car on so the radio works, when the radio comes on hit your source button that allows you to switch between the DVD player and the radio. You should now see a button that shows your Ipod. This will allow you to control your Ipod through the radio and the cable will ensure you Ipod is always charged. This should work if you have the correct cable...I actually just hooked up my Ipod to the exact same radio today using the CA-VDC300U and the expansion module.
Oct 28, 2008 | Panasonic CQ-VD6503U Car DVD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Panasonic Car radio CD CQ-C1110GN CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
