Question about Shakespeare Agility Spinning Reel 6825
Can you please show me how to remove spool from reel
3 Suggested Answers
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Posted on Jul 12, 2009
absolutely spot on
Posted on Apr 18, 2010
My line is wrapped inside the top of the reel
What you're referring to is known as bird's nest. You'll need to remove the entire line and re-spool it. How to spool a reel. https://anglersambition.com/
Jun 06, 2018 | Fishing
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do you put line on a magda pro star reel
Mount your reel on your rod. Run the line from your filler spool thrthrough the bottom guide of your rod. Pass the line througo the line guide on your reel and tie your line to your reel using an arbor knot. Put a pencil or dowel rod through your filier spool and have someone hold light tension on the spool as you reel line onto your reel.
Aug 03, 2014 | Okuma Magda Pro Linecounter Magda Pro...
How do you change the retrieve to left or right hand on a orvis encounter fly reel ?
Drag factory installed for left-hand wind. To change your real to right-hand wind, remove spool, pull the keyed bush and clicker plate assembly off the spindle. Flip the clutch bearing (silver) and reassemble.
May 21, 2014 | Orvis Encounter Large Arbor Fly Reels &...
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How in the bloody hell do I change this 'quick change spool' on my z03 omega? I can't seem to figure it out for the life of me...
Unscrew the front cone. While holding the handle unscrew the spinner head and remove from the reel. The quick change spool will have an arrow to show the direction that you twist it off. That's about all their is to it.
May 24, 2011 | Zebco Omega Spincast Reel
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Oct 18, 2009 | Shakespeare Agility Spinning Reel 6825
I'm trying to take apart this reel in order to clean and oil it. However I'm not able to remove the handles or the spool. Ideas?
Unless you know exacly what you are doing don't bother. It is a very complicated reel and expremely easy to put back together incorrecly. Send it off to Daiwa Sports service department. It'll either cost you £5 or nothing to have it serviced.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} T: 08450 603603
E: info@daiwasports.co.uk
Apr 19, 2009 | Watches
Shakespeare 2660 coarse fishing reel,cant remove spool cover
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Shakespeare Agility Spinning Reel 6825 Logo
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
