240CO - GE Carbon Monoxide Alarm - Green light blinks every 1-2 seconds , I just replaced this unit
I found this:
http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=462&prod_id=42
Flashing green every 1-2 seconds, chirps every 5 minutes = end of sensor life. Needs to be replaced.Replace the Sensor.
Posted on Mar 01, 2011
  • 2boysdad Jan 28, 2015
    Manual Found at: http://www.utcfssecurityproducts.com/Sit...
  • 2boysdad Feb 23, 2015
    The most Recent PDF Instructions:
    Copied from that document:
    Understanding the LED and Sounder
    The unit provides a multi-colored LED and a sounder to indicate the alarm status. The alarm automatically resets when CO is no longer detected. Use the following table to determine the status of the alarm.
    LED
    Sounder
    Status
    Description
    Green
    Off
    Safe air
    The alarm has power and is functioning properly.
    Red
    Sounds 4 rapid beeps every 5 seconds.
    Alarm
    Dangerous level of CO detected. The relay triggers if connected. Evacuate the premises. Press the TEST/HUSH button to silence the sounder for 5 minutes.
    Flashing amber every 30-60 seconds
    Chirps following each LED flash
    Trouble
    There is a problem with the alarm. Contact your monitoring company to investigate and replace the alarm as necessary.
    Press TEST/HUSH button to silence the alarm for 9 hours.
    Warning: When the unit is in trouble mode, there is a chance that the sensor may not detect CO levels.
    Chirps every 5 minutes
    End of Sensor Life
    Replace the alarm as soon as possible. Press the TEST/HUSH button to silence the alarm for 36 hours.
    Problem Solver:
  • 95 Answers
Should be fine. Usualy most CO units blink green to say it is alive and working fine. Double check your paperwork if you are not certain and the from of most of the GE CO detectors say what the lights are for.
Posted on Apr 21, 2008
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Carbon Monoxide Alarm Beeps every 30 seconds 7 years old
likely the batteries are getting low, or you may need to replace it, otherwise i hope you dont have a poison gas in your home
Jul 03, 2010 | Kidde KNCOBB Basic Carbon Monoxide Alarm...
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have 7 year old smoke and carbon monoxide alarm...I have put a new replacement battery and detector is chirping every 15 seconds or so
Check the expiry date on this unit. The manufacturer recommends replacement usually after 5 to 7 years depending on the model.
You bought a Combo Gas/CO Detector for protection against the hazards of Gas and Carbon Monoxide poisoning. A new unit will give you the peace of mind you are looking for.
Visit my website for more information and view most Brands and Models of Carbon Monoxide and Combo Gas/CO Detectors.
Dec 20, 2009 | Kidde Nighthawk Combo Gas/co Detector
My First Alert Carbon Monoxide Alarm has failed
If the carbon monoxide detector chirps, the battery may be dead. New batteries can be defective. Check if the light is yellow when the alarm is chirping, it means the battery is low, replace with a new battery.
Warranty service information:
UNITED STATES
BRK Brands, Inc.
3901 Liberty Street Road
Aurora, Illinois 60504
For consumer inquiries call: 800-323-9005
CANADA
Jarden Branded Consumables Canada
88B East ****** Creek, Unit 6
Richmond Hill, Ontario, Canada
L4B 4W2
Tel: 905-482-3720
Fax 905-731-8267
For consumer inquires call: 800-323-9005
If you are looking for new Carbon Monoxide Detectors, visit my website.
Oct 01, 2009 | First Alert Safety & Security Carbon...
I have a British Gas carbon Monoxide alarm - recently changed the batteries but it now beeps once every minuit, instructions on the inside of the cover says refer to manual - but I can't find. Any idea...
I am having exactly the same problem. It says that the batteries cannot be changed (ccould just be ploy to get us to buy a new unit). mine is only 4 yrs old, and has never beeped before - the light used to blink once when i entered the kitchen. It is now beeping intermittently once per minute same as a smoke alarm needing a new battery.
Apr 10, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Carbon monoxide detector err code
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
Aug 13, 2008 | Kidde Nighthawk Combo Gas/co Detector
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
