Question about Asko Dishwashers
Dishwasher filling up and over flowing. switch to turn on pump comes on late or when I manually put pressure on drain. Have hard water and found much scale. could sensor/float scale cause this? Thinking about filling with white vinegar and letting sit so I don't have to take apart. Thoughts?
  • 478 Answers
Take a packet of unsweetened lemonade any brand and run it through a cycle. This will clean all the scale and calcium from the pump and spray arm to improve the circulation of water in the machine.
Posted on Jul 10, 2010
Aeg slimline dishwasher 64800. AL5 alarm, but fills up
This control procedure is in operation only during the cold wash and heating phases.
  • Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
  • The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
Alarm: AL5
Possible causes:
  1. Dishes upside down
  2. Central filter clogged
  3. Siphon effect created in drain hose
  4. Leakage in sump - pressure switch tube.
Dado
Mar 02, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Model D1776 Continues to Fill with Water/Drain Pump Engages After Wash Cycle Is Complete
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Oct 24, 2011 | Asko D1776 Built-in Dishwasher
Ge dishwasher about 7 years old as soon as we start it we hear the water turn on to fill but it does not fill water it imeadily start draining
Hello
Water Not Flowing Properly
Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
Sep 12, 2011 | Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Dishes dont come out clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 30, 2011 | Jenn-Air 24 in. JDB1050AW Free-standing...
Hi, My dishwasher is about 6 years old and lately it is not properly washing the dishes. We've noticed that the glasses look foggy and the plates are sometimes not as clean as they used to be. Also usually...
Hi
If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Kenmore Dishwashers
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
71 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
