Question about Kenmore Coffee Makers & Espresso Machines
I need a new water filter for the Kenmore coffee machine
I need a new water filter Item #69768 for the Kenmore coffee machine 100.80666700A. Myrt Ellis
Check Lowe's that is were I get mine!
Posted on Aug 20, 2010
  • SKELLY311 Sep 21, 2010
    THANKS, BEEN GOING NUTS TRYING TO THIS FILTER.
  • wvlabordoula Nov 28, 2010
    If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack) http://www.sears.com/shc/s/p_10153_12605...
I need a replacement filter for my kenmore coffee maker item#69768
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
I am looking for a charcoal filter #69768 for my coffeemaker model #80666 where can I order?
Oct 26, 2010 | Kenmore Coffee Makers & Espresso Machines
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 14, 2010 | Keurig B60 Coffee Maker
Will not brew
mcdevito75 here, Your coffee maker may need cleaning, if so, fill the resovoir with WHITE VINEGAR and cycle thru 3 times, have clean or new filter in the machine, on the 3rd cycle stop machine for 30 minutes then resume, cycle thru2=-=3 more times if needed, after the vinegar cycle change filter or clean and cycle thru plain water 2--3 times or more to rinse out the vinegar.
Jul 10, 2010 | Kenmore KBC12 Coffee Maker
Water does not come out ...is there a fix
mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Jul 09, 2010 | Mr. Coffee TFTX85 Coffee Maker
Not all of the brewed coffee water is going through to the cup. I have done a quick check to see if I could find a fault with the pipes or seals. Can't seem to find where the brewed coffee water is coming...
Hi
More than likly you have a striped thumbscrew. That is the item that holds the filter screen in on the brew unit. If you use the key to tighten the thumb screw you will pull the nut out of the thumb screw and they is nothing to hold the filter screen in and it leaks past the thumbscrew into the drege drawer. If you remove the brew unit and there is water in the pocket by the thumbscrew its striped and needs to be replaced. Be sure to remove the extra nut on the filter screen before installing the new thumbscrew.
Jun 18, 2010 | Saeco Incanto Classic Espresso Machine
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
NO...I am looking for a KenmoreFilter # 69768 Purshase at Sears and they DO NOT carry the filters.Its time to change the water Filter. Please see if you can help me. Wanda V.Neal wanda_v_neal@hotmail.com
Apr 19, 2009 | Oster 10 Cups Coffee Maker Model 3297-053...
Kenmore Elite coffeemaker water filter
http://www.kenmore.com/shc/s/p_10153_12605_00869768000P?filter=Price%7C%240-260%5E&vName=Appliances&cName=Small+Kitchen+Appliances&sName=Coffee%2C+Espresso+%26+Tea+Makers
Try here. Hope this helps.
Oct 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
201 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Steven Clarke
Steven Clarke
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
