Question about GE Profile JVB67HWW 36" Telescopic Downdraft Ventilation System: White on White Kitchen Hood
I have a GE Profile down draft fan that won't retract
I have a GE Profile down draft fan by my cooktop. I can't get it to go back down after using it for the first time since we purchased this house.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: instruction manual
Try this it might not be yours but it is a manual. If I get the model # I can get you the right manual.
http://www.ajmadison.com/ajmadison/itemdocs/Dispatcher_REQUEST=ITEMID&itemid=49-80216.pdf
Good Luck and Please Rate FixYa!
Posted on Feb 27, 2009
  • 1214 Answers
SOURCE: GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: ge profile gas cooktop -
Perhaps you have a similar problem that I did. I have a Whirlpool gas range and some of the lighters were cracked and not working. They are $26 - $35 each, OUCH. On the two broken ones I replaced the ceramic with epoxy putty, and they are working. As it turn out, they are only female wire connectors wrapped with ceramic. In a hobby store I got some oven bake clay, an I plan to make my own replacements.
Posted on Apr 21, 2009
SOURCE: GE Profile JB 968 Hot Cooktop Indicator Light Always On
Temporary solution to turn off the indicator lamp - put a wet rag with an ice pack on top on the middle section of the cooktop.
The thermal sensor will trip off the lamp.
Posted on Apr 24, 2009
Replace fan switch on ge cooktop profile
I agree completely with imaginus2000. GE Profile is junk. Came with the house we bought so had no choice there. As soon as it craps out it will be sent where it belongs. The scrap yard!
May 26, 2012 | GE Profile 36" Electric Induction Cooktop...
GE Profile cooktop JP360. Trying to remove cooktop to install new granite countertops. Also have GE built in oven JTP 15 below. Called G.E. Customer Service today and was told to just pry the top off...
Hi marilynmcdon,
You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
Hope this helps
JEDEMEYER1
* If this solution helped you, please rate it.
Aug 09, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Down draft kitchen cooktop: i can't use a recommended 6" exhaust because of structural conflicts, but could use a 3". Will this mess anything up with the blower on the cook top?
This would be a bad idea. The problem would be that not all of the exhaust gases will leave the kitchen. (Thus it could make you ill or be fatal - it will not do be a problem for the blower.) For a very short run you can use 5" duct but not after any sections of 6" or 3 1/4" x 10" rectangular ducting. The maximum duct length can be 100'; however 5" round duct has a higher equivalence length than 6" round duct.
You would be better off putting the cooktop on an exterior wall and directly venting it to the outside with rectangular ducting.
The installation and owner's manual are available from GE. Go to http://www.geappliances.com/service_and_support/literature/. Then search for JP389.
I wish that I had better news.
Dec 17, 2010 | GE 30 in. Profile Select-Top JP389...
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Nov 15, 2009 | Jenn-Air JED8430 Electric Cooktop
How do you get the black top off. I have to put in a new front burner. Thanks.
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
Turn off the circuit breaker to the cooktop. Verify by making sure the burners/fan do not come on. Disconnect the exhaust fan (underneath the cooktop) from the ductwork by removing the tape that joins it. While you are underneath the cooktop, open the junction box. Label the four wires that are joined so that you will be able to connect them later. Then disconnect the four wires. Remove the metal sheating that connects to the junction box (there is a nut on the inside of the junction box that you loosen. Pull out all the supply wires (from the mains) from the junction box. Then push the cooktop up and out and lay it flat on a table with the flat side down.
Take off only the top row of screws all around the unit. Rotate the unit so that you can get to the down draft cavity (the down draft cavity is where the grease guard mesh is). Remove the two center screws. Then pull the black top off.
For an exploded view of the unit check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
Sep 03, 2009 | Jenn-Air JED8430 Electric Cooktop
Heaters won't turn on
I would certainly call GE on this one!
Jul 24, 2009 | GE 30 in. Profile Select-Top JP389...
Downdraft from exhaust fan
you definalty should feels air moving, providing hte unit is ON. when not in use there should be mo draft( minimal at best) if there is still a draft when unit is off, i would check where it exhausts outside, there should be flap tha closes when not inuse
Dec 21, 2008 | Gaggenau 36 in. CI491610 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Kitchen Ranges Logo
252 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
