Question about Tag Heuer Aquaracer Chrono Automatic CAF2010.FT8011 Gents Watch
I have the tag heuer aquqracer chrono automatic it keeps time just fine but the day and date doesnt change
  • 203 Answers
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
Posted on Nov 22, 2008
  • 11 Answers
SOURCE: Tag Heuer - Aquaracer automatic (Day/ Date)
Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
Posted on Jul 31, 2009
Bob Gemmell
  • 209 Answers
SOURCE: Tag Heuer watch runs fine; can't set time or date.
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
Posted on Aug 07, 2009
  • 93 Answers
SOURCE: Tag Heuer WK1110 Date Changing Problem
This could be caused by a couple of things. To fix this would require a qualified watchmaker to repair. The watch will need to be taken apart and the dial and hands will need to be removed to repair this problem.
Normally when we see this problem one of the wheels needs replacing. This can be caused by manually changing the date near midnight.
Let us know if we can help more.
Ken
Yellowstone Watch Inc.
Posted on Oct 05, 2009
escapement
  • 2334 Answers
SOURCE: Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Posted on Mar 25, 2010
Testimonial: "Thank U so much for the enlightenment, escapement. Your points really do ease me alot. Will go to retailer/svc shops and we'll see from there. Cheers!"
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Need manual on operation of Tag Heuer ''Chrono'' watch . Leather band w/rose gold bezel.
I would contact Tag for this one. Most watch vendors will provide them at no cost. Be prepared to give them the #'s on the back of the watch to ID your watch.
http://www.tagheuer.com/
Good luck.
Jul 23, 2010 | Tag Heuer Automatic Chronograph Series...
Mar 25, 2010 | Tag Heuer Automatic Chronograph Series...
I have a tag heuer aquaracer crono automatic and i can hear it and feel it when its self winding is this normal?
this is normal if you didnt i would be worried..all automatics do this its the rota in the back theres no such thing as a silent automatic in the trade we call them swinging bricks..
Mar 23, 2010 | Tag Heuer Aquaracer Chrono Automatic...
Ken
Oct 05, 2009 | Watches
Jul 31, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
The date changes at 12 in the evening
The watch is set-up for a 24 hour cycle. It sounds like your watch is 12 hours late, so if you just advance the time 12 hours ahead, everything should be solved.
May 23, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Open Questions:
Tag Heuer Aquaracer Chrono Automatic CAF2010.FT8011 Gents Watch Logo
41 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
