Question about Siemens 24 in. SE25A266 ExtraKlasse Free-standing Dishwasher
My siemens dishwasher runs for about 4 hours what's the problem?
  • Siemens Expert
  • 414 Answers
Could be the instantaneous water heater, the power module or both.
Or it may not be taking sufficient water to allow the heater to turn on as it has a boil dry safety. Check the following to rule out water shortage
if you remove the lid (no screws on lid, there are two clips at the rear, release them and the whole lid will slide back and then off) and take the two t20 screw off the left side panel at the front you should check the pressure chamber and its hose are not blocked. Use the link and go to page 4 to see where they are located, parts 480748 and 298556.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SE25A266GB%2f27&ESHOPTYPE=S
Best of luck.
Posted on Jul 11, 2010
My siemens dishwasher wash cycle keeps going. It should be done after 2 hours but the timer count either stops working or moves much slower than the allotted time. Ideas how to fix it?
You cannot fix it since you may not have the knowledge to do so. Maybe all that is needed is a new timer, but only a trained tech can determine that.
Feb 23, 2015 | Siemens Dishwashers
Siemans sl33a dishwasher won't drain, interior is scummy
My Siemens runs constantly, for hours, and doesn't drain all the water from the bottom. Is this also a "clogged drain" issue or is there something else wrong?
Jan 01, 2013 | Siemens Dishwashers
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
Feb 07, 2011 | Siemens 24 in. SL34A006UC Built-in...
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Dishwasher runs about 3 hours
First check the inlet water flow into the machine. There is a strainer attached to this. If it is clogged water filling into the machine will be delayed!
Also check whether using the same wash program as you were doing earlier. There can not be any other fault aprt from this. i presume the wash quality is good.
Heance clean all the water inlet and outlet for free flow.
Jul 08, 2010 | Siemens 24 in. SE25A091 Hi-Line...
Siemens dishwasher stored for 6 months.Not working.
might be water valves stuck try giving entry pipes a tap. no too hard though
Jan 15, 2009 | Siemens 24 in. SE25T250 Free-Standing...
Siemens 24 in. SE25A266 ExtraKlasse Free-standing Dishwasher Logo
767 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
