Question about Kitchen Ranges
I am trying to find out the proper procedure to convert my holiday gas range to propane. The model is GAK10100. I would like to know who makes this stove and if I might get an owners manual
Posted on Dec 07, 2011
How to change from natural gas to propane
Hi Rodney.
the main change from natural gas to propane is that propane has a bit higher energy content than natural gas, so you may heat things a bit faster. The particulars will depend on your specific make and model of range, but, for instance, with my KitchenAid gas range, the primary difference was getting a slightly different connection orifice made to give proper propane flow and pressure. The install kit may also have listings for necessary delivery pressure ranges from you propane source. If the range is built in, it might be a bit of a pain to get at the gas connections, and it's best done by a professional who will know the proper fittings, seals, and pressure tests to do to make sure you aren't leaking gas all over your kitchen.
That said, it's likely not a particularly big deal.
Good Luck!
D
Nov 24, 2015 | Kitchen Ranges
I have a new Frigidaire Professional gas range. I am trying to convert it to propane and I do not know how to convert the oven burner.
need to get a conversion kit if not already set up for one the pressure is different between natural gas and lp/propane gas set ups
Aug 29, 2015 | Frigidaire Kitchen Ranges
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
Wanting to change propane stove to natural gas,need parts to do that
Most ranges can be converted with the orfices being changed.Newer ranges have the orfices under the top.Older ranges can be convetrted by drilling the orfices larger.(propane orfices are smaller than natural gas.Sears can sell you a conversion kit if you know the model and serial #.Most Gas companies will convert it for a fee.
Mar 05, 2014 | Kitchen Ranges
How to convert a 61" residential rangefrom butane to natural gas?
Ranges come set from the factory for natural gas. To convert it to propane, you should call your propane co and have a qualified serviceman do the work. You can void the warranty if you try to do it yourself and break something or don't convert it correctly. On an expensive range like this, you'll be better off having a professional do it right and keep that warranty intact. It could take 1 1/2 to 2 hours to complete the job. You may need to purchase an LP conversion kit if some of the orifices have to be exchanged, like on a unit with sealed stovetop burners. Write down the make, model # and serial # for reference when you make an appt to have it done. Hope that helps.
May 22, 2010 | Imperial Commercial Cooking Equipment...
Kenmore gas stove can it be changed to work for propane
Yes, your gas range can be converted to propane. Your owners manual will give you step by step instructions. Since there are many different models, there are different procedures involved to convert to propane. On some models you must change the top burner orifices where other models have adjustable orifices. The oven burner has an adjustable orifice(same with broil burner if there is one). The range regulator must be adjusted to stay open all the time because your propane system has its own regulator.
Mar 21, 2010 | Kenmore Kitchen Ranges
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
GAS RANGE
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Jun 13, 2008 | Kitchen Ranges
Kitchen Ranges Logo
540 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
