Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2004 HD roadking, FI.
When cold will not do more than 3000 rpms, after about 5 miles ok, two hd dealers could not find anything, repld. temp sensor same problem, starts ok
    Scholar:
  • 150 Answers
Had the same issue with an early twin cam that belonged to a buddy. he had this wierd kinda intake thing that looked like the intake with the round flaps that you used to see on a hot rod back in the day. I don't think it did anything but look cool to him.
but anyway it was crazy hard to warm up when cold. if you are starting this bike in an ambient of 40f or less it will take some time to warm up. which I don't understand because the twin cam runs hot like 220 plus. give it extra time to warm up in cold weather. might be nothing wrong with the bike... I mean maybe what your up against isn't a breakdown of the machine but poor engineering (WHO SAID THAT?) anyhoo I've seen it too and everything was tip top far as the HD cronies said
Posted on Apr 21, 2008
Is SAE 5W - 30 ok for my old Jeep and Cheyenne...
Its probably ok but I would recommend 10w30 for anything with more than 100,000 miles on the odometer.
Also, 5w30 works better in colder temps, the first number is the "cold thickness" and the second number is the "hot thickness". The bigger the number the thicker the oil in basic terms.
Apr 04, 2016 | 1997 Jeep Grand Cherokee
2009 HD roadking EFI problems bike will only idle??
Lots of bikes have been going into limp home safe mode. My only experience with a correction has been replacement of the hand grip actuators.
May 15, 2014 | Harley Davidson FLHR Road king Motorcycles
I have a 04 hd roadking classic with only 140 psi on cold compression test. When i squirt oil in each cylinder i get 155 psi and 180 psi No loss of psi on the first leak down test
Unfortunately, you're NOT going to get an accurate reading with a cold engine, it needs to be up to full operating temperature!
Also, as much air as possible needs to be allowed into engine, so remove aircleaner/filter, and hold throttle WIDE open while cranking engine to get reading.
Feb 11, 2013 | 2004 Harley Davidson FLHRCI Road King...
MY 2001 ROADKING WITH CARB I INSTALLED 95 IN
Try and get the carbs balanced .You may have one in need of adjusting .
Mar 17, 2010 | 2001 Harley Davidson FLHR - FLHRCI Road...
No heat
You need to bleed the cooling system of excess air and add aditional antifreeze.
Dec 15, 2009 | 2006 Nissan Frontier
Bike shuts off after stopping. no engine check light comes on nor does the FI light come on. 2002 GSXR 1300 4034 original miles
A very young bike to be having problems (Low Miles) did this start after refill at the gas station? If the bike is hesitant and dies when stopping it could be bad fuel, if not is the day temp cold? if so it could have a faulty ATS (Air Temp Sensor). If bad fuel is the issue drain the tank completely and fuel lines, clean the fuel filter on the fuel pump. Refill with clean fuel and it should be OK. If the air temp is cold, check the ATS values with a multimeter. Another thing to check is for any airleaks around the throttle bodies, check all vacuum lines are secure and rubber plugs are in place.
Nov 22, 2009 | 2002 Suzuki GSX 1300 R Hayabusa
2003 HD Fatboy has a miss. New plugs and wires.
i take it its carb. after it warms up to operating temps does it stop the sputtering? thats just a HD CV carb doing what it does til hot. Im not talking a 2 min warm up and off u go im talking operating temps of 200 plus. Is the carb an S&S? Your going to have high rpms til the temp kicks it down if its injected
Oct 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
I have a 97 Fatboy that sometimes loses spark
test or replace your ignition module,and you might find the actual prob by accident the connector for the module sometimes with age lose or only have intermittant contact.a can of electrical contact cleaner should take care of it but those symptoms scream ignition mod dont know why hd dealer couldnt find it but they dont put their best techs on older bikes
Jul 15, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
163 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
