Question about KitchenAid KAWS850L Top Load Washer
It does not drain after the rinse cycle.
I have an 850 JQO. It just stops when it is supposed to drain. We noticed that the breaker was tripped and after we turned the breaker back on, it would not complete the cycle.
  • KitchenAid Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineIt does not drain after the rinse cycle. - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 12, 2010
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
My GE 15 cycle heavy duty plus washer the water keep running in the rinse cycle
Hum the water inlet valve may be going out or defective, have u noticed any water in tub at bottom when machine is not in use or after a day or so? check it with multimeter. Another suspect could be a bad timer sticking on rinse cycle, or a bad water pressure switch, which is suppose to shut water off at certain water level then start the agitation? In other words when in rinse and water is draining, the pressure switch continues to read low and opens to keep the water flowing to replace water that is lost? Need a multimeter test on all of them
Sep 26, 2014 | Washing Machines
Maytag Quiet Series 300 Dishwasher will only run part of wash cycle before tripping breaker?
I'm thinking dishwashers is installed in correctly. Too low causing an issue. Have a tech look at it.
Nov 17, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
The dishwasher starts and initially rinses the dishes without heated water. In the next part of the cycle, the water is supposed to heat to a certain temperature.Beginning this morning, in this second part...
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Dishwashers
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
KitchenAid KAWS850L Top Load Washer Logo
87 people viewed this question
Top KitchenAid Washing Machines Experts
gbob59
Eric Taylor
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
