Question about Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower ()
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
New gas. Cleaned spark plugs. Lawn mower starts-up and then stops.
    President:
  • 2,702 Answers
It sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Posted on Jul 10, 2010
Craftsman 18.5 hp, 42"cut, riding lawn mower quits running after 10 minutes
ONE OF OR YOUR COIL PACK...(UNIT PLUG WIRE COMES FROM IS PROBABLY DEFECTIVE
Jul 29, 2012 | Craftsman Garden
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Was running stopped it for 1/2 hour, and would not re-start
IT LOOKS LIKE YOU COIL MAY HAVE CRAPPED OUT ON YOU. THEY NORMALLY WILL QUIT WITHOUT WARNING
Mar 28, 2010 | Garden
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Crafsman Eager 1 6.75 HP lawnmower wont start
I have an Eager 1, as well and when I try to pull the cord it does not turn at all. It's stuck. I hit a tree root and since then I have had problems with it. I have 2 mowers so it was not used last year at all. Gas was drained and it was stored in a shed. Anyway, I know nothng about mowers other than spark plugs, gas, oil, sharp blades and filters. Is the motor seized? Thanks
Feb 15, 2009 | Garden
Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower () Logo
304 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
