Question about Linksys Wireless-G WRT54GL Router
I am trying to install a Linksys wireless-G broadband router.If I connect my BT voyager voice router to my laptop with a cable the internet connection works but when I connect the new wireless router to the laptop to configure it I get the message that it is unable to connect to the internet?What could the problem be?
  • colm_heron Jul 10, 2010
    Yes I am using both the CD that came with it and the cable that came with the new router.
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
AvioriX
  • 689 Answers
SOURCE: WRT54GX4 Wireless Router Setup Problems
Hi Randy
Reset the router
Use regular way to configure the Router.
In computer side
Go to Start>Connect To>Show all connections
a new window (Network Connections) will open,
Right click on the "Wireless Network Connection"
Click on "View Available Wireless Networks" You will see "linksys" with the highest signal level. Connect it
after connection go to web browser; type 192.168.1.1 and hit enter. It will take you to Linksys setup page which is integrated in the router. after that you can do any settings you want.
Please post here if you need further assistance
Good Luck
Posted on Jan 12, 2008
2Gigs
  • 141 Answers
SOURCE: Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Posted on Mar 15, 2008
luiskiev
  • 144 Answers
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Posted on Nov 07, 2008
dante777
  • 623 Answers
SOURCE: Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Posted on Dec 29, 2008
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Mar 03, 2011 | Linksys Wireless-G Broadband Router
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
New Laptop Connection
Are you connecting and configuring using wireless or cable?
Sep 07, 2008 | Linksys Wireless-G Broadband Router
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Linksys Wireless-G WRT54GL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
