We have a Epson Powerlite 77c Projector and the lamp light will not come on. The Projector powers up and when the green light comes on the direction say to push the menu button to reset the lamp but it never comes on instead the projector will then shut off automatically. We have replaced the lamp 2 times thinking it was that. Just bought a new lamp (bulb) and installed it. Please help us figure out what might be wrong.
  • 11,896 Answers
Test the power to the ballast with a voltmeter. The ballast can go bad. If it tests bad, then replace it. If it test good, use an analog meter and test the resistors and capacitors to make sure they haven't been overheated.
Posted on Jul 10, 2010
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
I have hooked my Epson 77c to cable in the following method. Cable directly into old vcr, vcr cabled into tv, RGB cable from vcr out to Epson 77c video input. The issue is that I can view only channel 3 on...
VCRs typically do not have RGB outputs. If you are using the VCR as a tuner for your projector, then be sure you have selected the VCR/TV button to VCR then your VCR will be the tuner. If you have it set to TV then the signal is passed through the VCR by your coax to the TV and the TV is the tuner but the VCR is now only outputting Channel 3.
Feb 22, 2011 | Epson PowerLite 77c Projector
Epson 77c Projectors occasionally freeze - controls don't work
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Mar 16, 2010 | Epson PowerLite 77c Projector
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
