Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
What is a code 94 on the salt generator - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • William Brandon Jul 15, 2010
    Thanks
    It looks like this thing is pooched it will run a few hrs and shut down I think the transformer is overheating.
IT MEANS NO INPUTUNLOCK IT THEN SET IT TO DESIRED TIME
Posted on Jul 14, 2010
  • 297 Answers
Just try unplugging it to reset. There is no code 94 in my manual
here is a link to manuals and videos to possibly further help you
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Posted on Jul 12, 2010
Testimonial: "Thanks left it unplugged for half an hour since the transformer was over heated, Works fine now."
2 Suggested Answers
  • 368 Answers
SOURCE: have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Posted on Aug 24, 2011
Low salt
The salt chlorinator cell should be cleaned with a proper cell cleaning fluid. Your pool surface may coat the salt cell with calcium and unless this has been removed it will not generate chlorine efficiently no matter how much salt you add to the pool water.
When the salt cell has been cleaned properly then the amount of salt in your pool may exceed then recommended concentration and it will overload the power supply to the salt cell and the salt concentration will need to be reduced.
Mar 30, 2012 | Intex Pool & Spa
Have an intex 16 x48" salt water pool generator
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Flashing code 94 model 8110
Here is the list of codes and can't find 94??? Sorry...
Jul 31, 2011 | Intex Automatic Salt Water System for ...
I have forgotten how to set my salt water system to initially chlorinate the water after i added the salt. It keeps beeping and the code says no salt is detected.
Could be a couple of things. Have you put the right amount of salt in according to the tables (I find I always have to add a bit more then the tables say). Have you let the salt mix completly by stirring up any salt laying on the bottom of the pool and by running the pump for at least 24 hours before turning on the salt generator. Depending on how large the pool is you may need more than 24 hours before turning on the salt generator. If still doesnt work than you can try adding more salt a little bit at a time over a couple of days. Also check to see if the electrolytic plates need cleaning. Unscrew the large grey connector to the left of where the wire goes into the sensor and look inside the unit on the left)
Apr 04, 2011 | Intex Automatic Salt Water System for ...
KEEP GETTING A CODE 91 LOW SALT?
As mentioned in many of my post's, you can not just go by the reccomended amount of salt in the owners manual.
You must get salt test strips that read in #'s not colors and get your salt as close to 3000ppm as possible lower than 2800 and you will not generate enough chlorine or trigger low salt alarms
any higher than 3500ppm and you could get cloudy, or trigger high salt alarm
the water will also taste too salty when adding salt dont forget to stir up the water and filter only for at least 12 hours before trying to generate salt
Longer if you ad a lot of salt like 75 lbs or so
Jul 19, 2010 | Intex Automatic Salt Water System for ...
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
Jun 30, 2010 | Intex Automatic Salt Water System for ...
Code 91
If you have hard water in your location you may want to try cleaning the electrolytic plate. I had the same issue where no matter how much salt was added I had code 91. I shut the water down going through the filter / generator. Pulled the outlet hose off and put on a cap. Pulled copper cell out and filled chamber with vinegar. Put cell back in and let set for 1 hour. Fluhed it out and hooked everything back up. Nop more salt problems. The process is in the book.
Jun 07, 2010 | Intex Automatic Salt Water System for ...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
Salt light flashing added salt light went to orange no longer flashing but no chlorine lights will light has been 29 hours
All salt generators need at least 4-5000 parts per million for up to 30 days for the generators to re-generate salt. it takes chlorine to combined with the generator and salt to regenerate salt. Salt generators do not make salt from water that is not chlorinated first.
Try This and you will re gererate chlorine.
The Pool Tech
Jul 16, 2009 | Zodiac Duo Clear System Chlorine...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
267 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
