Question about Hotpoint NBXR333EGWW Dryer
Leaving burm marks on clothes
My dryer is off balance and it leaves burn marks on the clothes
    President:
  • 2,702 Answers
Its getting to hot,,,check its air intakes to see if there blocked up and also the hot air outlets (hose pipe) if thats blocked up change it
Posted on Jul 12, 2010
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Hotpoint NBXR333EGWW Dryer Logo
120 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
