Question about Bosch Water Heaters
Hello, I purchased a Bosch model # GWH G35 ES N about 4 years ago and have continuous problems with the sensors. I've replaced the hot side outlet sensor #0711 at least 4 times and the cold side # 0616 just twice. The problem is that when the hot water is required from any apliance, shower, sink, etc., it comes out scalding hot as if there was no temperature regulation at all and then it just cuts out after about 2 minutes, going completely cold. I am ready to ditch this unit and go back to a conventional gas hot water heater. Thank you for any feedback you can provide. Glenn
    Scholar:
  • 122 Answers
The main problem is...
you purchased a "Bosch" Aquastar.... complete garbage
if you want quality tankless..
Takagi, Rinnai, or Noritz. these are the only tankless I install or work on, very few if any problems.
just look on the board here, most of the problems listed are with the Bosch
Posted on Aug 06, 2010
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
Jan 02, 2014 | Bosch ProTankless GWH 715 ES LP Tankless...
Where can I download a Boschw14 b31 gas Heater Manual
Is this a water heater? Bosch site might have manual. And service bulletins, but I have not heard of that model.
http://www.bosch-climate.us/Bosch-Hot-Water/
Call local service technician who is qualified to work on tankless computer that heats water.
You can fix any brand tankless computer, any problem, same day, yourself by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
l
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 05, 2013 | Bosch ProTankless GWH 715 ES LP Tankless...
Where can i download a GWH 715 ES manual?
Are you looking for sell sheet pdf, or install-care manual, or service manual.
Search: GWH 715 ES manual .pdf
Adding .pdf to search parameter helps locate manuals.
Sell sheet with venting overview, technical and product specs:
http://www.globaltowne.com/manuals/sell_sheets/715-800SellSheetFINAL.pdf
Manual for ES high altitude, with installation, error codes and troubleshoot:
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
I cannot find a service manual, or service bulletins:
http://www.bosch-climate.us/support-center/downloads/bosch-manuals/earlier-models.html
Aug 11, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
E4 code on a bosch ghw 715 control unit
Before calling service technician, open following link for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshooting, and solutions vary by model and unit.
E4 is Backflow temperature sensor over 309 degrees F. Appliance will close burner and lock.
Check combustion air and backflow vent piping for blockage.
Check if secondary fan connections are disconnected.
Check venting specifications are met. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
Check sensor resistance
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Mar 16, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Burner will not light
Try this web site!
http://www.protankless.com/BoschProHome/GasProducts/BoschGWH425HN/tabid/506/Default.aspx
Copy & Paste to Google search engine.
Jan 27, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Water Heaters Logo
138 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
