Question about Sony CDX-L480X CD Player
Stored radio stations are erased every time I take the key out of the ignition
  • Sony Master
  • 4,946 Answers
There are 2 battery feeds to your radio.
The main one via the Ignition Switch controls switching the radio ON/OFF
The other one is a permanent connection that feeds the memory chips on your radio.
It is this second/permanent feed that is missing.
Check fuse, wiring and connectors
Posted on Jul 10, 2010
When I start my car and I turn on the radio all my stored radio station is erased and this is starting to happen all the time I start the car. Please advise what's going on with my car... Thanks!
Check your fuses. The radio needs residual power to keep the memory alive. When you shut the vehicle off it isn't getting that power so the memory gets lost.
Jun 24, 2011 | 2002 Toyota Sienna
My friend has a citroen AX in which we now have a working radio, only issue is that it doesn't remember any stations stored.
There are 2 battery supplies to the radio,.
The main one via the ignition key circuit for the radio itself.
The other one is a permanent battery feed to the radio memory.
It is this second (permanent) feed that is missing.
Check the fuse, connectors + wiring to see if there is anything obvious.
If you have a multimeter or test lamp then that can be used to prove the problem
Sep 06, 2010 | Car Audio & Video
When you locate the stations and store them then leave the car for any period of time or turn radio off, all the stations you previously stored have all disappeared and you have to retune again!
Sep 04, 2010 | Pioneer DEH-P4100
Sony cdx-gt100 cd player radio stations are not storing,i have stored them all but as soon as you turn the ignition key,the stereo has lost all stored stations.thanks for any help
You will need to check the yellow wire of the stereo. This wire must have +12 volts even with the key off. Be sure it has a good connection.
Mar 08, 2010 | Sony CDX-GT100 CD Player
Trouble storing radio stations
IF this aftermarket fitted then the ignition live and permanent live feed to the stereo are configured round the the other way on the head unit.i think it may be the red wire and yellow wire need swapping.
Dec 30, 2009 | Radio Communications
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 16, 2009 | JVC KD-HDR1 CD Player
Stored radio stations and time erase when car is turned off
The radio was installed incorrectlly. Make sure the red wire from the radio is connected to a switched 12 volt source(has voltage when car is on, none when it's off) The yellow wire to a constant 12 volt(hot at all times) this wire mantains the radio memory and must always have power.
Nov 21, 2008 | JVC KD-G220 CD Player
Stored settings and auto eject
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Sep 25, 2007 | Dual XDM6830 CD Player
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Sony CDX-L480X CD Player Logo
188 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
