Question about Photography
Have Olympus om77af with battery cover door broken need new door?
SOURCE: broken battery cover.
I have a broken battery cover on my Olympus Camedia C-370 zoom digital camera.
Would you let me know, where I can obtain a replacement. I live in SW France.
Posted on Mar 21, 2008
SOURCE: Battery door.
Hi, waiting for the replacement part, I had a look at the broken one . I think you may be able to replace just the plastic part without removing the pin. I'll look closer when I get the part.
Posted on Oct 28, 2008
SOURCE: Broken Battery Door
I have the same hp 850, No way to fix it, So to hold the Battery Door Down, I Drill'ed a small hole through the top. & through the case
where, the camera latch Broke, & do it Real Slow..... Put a Sheetmetal Screw in the hole i drilled & it Work's Find. Just do it SLOW<<<<<<<< Good Luck & it's up to You What size to use
So Think it Over before you Try it....Slow slow slow, & the right size Drillbit,screw, & turn it in Slow.. P.S. It was do that! or $500
Down the Drain, Good Luck, The Wizard
Posted on Mar 08, 2009
  • 244 Answers
SOURCE: Fujufilm S700 won't power on. New batteries.
Yes it will. The door activates a micro switch that cuts power to the camera when open to prevent accidental removal of the card and loss of pictures stored on the card. You can bypass this switch with either a solder "bridge" or remove the switch and use a piece of wire to bridge the pads on the board.
Posted on Apr 21, 2009
SOURCE: Broken battery compartment door switch
My Olympus Stylus 9000 camera fell. Now the battery/card compartent door will not close allowing the camera to turn on.... I think I may need to place the door? I am not sure why it will not close.... Possibly something broke off????
Posted on Sep 27, 2009
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
BATTERY COVER DOOR BROKEN OFF OF A C740 ULTRA ZOOM OLYMPUS CAMERA
Hello :
Check these links for purchasing another one : Link1 , Link2 .
I hope this will help .
Please don't forget to rate !
Jun 10, 2010 | Olympus Camedia C-740 Ultra Zoom Digital...
The latch on the camera door is broken. Can it be replaced?
Sure.
Replacement covers on their own rarely surface on ebay, but you might be lucky and find a "donor" camera with a working cover - it will probably work out cheaper than trying to order directly from olympus or their parts department.
The battery cover is attached to the back cover of the camera, you'll need to unscrew it (make sure you take notes of which screws go where as they are not the same).
Hope this helps,
Good luck,
Raf
Nov 13, 2009 | Olympus 8.0MP Digital Camera Holiday Gift...
FE-140 Battery compartment door broken
battery cover has small and minute parts so it breaks easily. getting a spare is difficult. only easy solution will be to take it to service center and fix it
Jul 29, 2009 | Olympus FE-140 Digital Camera
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Battery door.
Jul 28, 2008 | Olympus FE-210 Digital Camera
Broken battery cover.
Jan 08, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus Camera
you need to puchase a new battery door see ebay
Nov 20, 2007 | Olympus Camedia D-370 Digital Camera
Olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
http://www.digitalcamerapartsdepot.com/Olympus_Parts/VK127200.asp
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
Nov 09, 2007 | Olympus Stylus 710 Digital Camera
Photography Logo
197 people viewed this question
Top Photography Experts
TC CAMERA REPAIR.Com...
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
