Question about Lands Phones
Phone not working. phone says place on main base to register
Figured out about which base was the main base so it worked
Posted on Apr 27, 2008
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
Okay I have an at&t brand CL82209. The one with the big main base and the little other one. So the main base works and its fine and all but we need the second one for our other room in the office and...
There is a simple FIX here:
From the "Connecting...." handset, type *331734# then hit MENU button.
Boom..... handset should now read "NOT REGISTERED"
Now you're ready to follow the manual directions:
  • Place handset on main base
  • Hold "Handset Locator" button until red light solid
  • Remove handset and then place back on base
  • Handset should now be registered
You're done!
Jun 12, 2010 | AT&T CL82209 Cordless Phone
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Second phone not working.
From the manual:
VERY IMPORTANT: BOTH HANDSETS MUST BE REGISTERED TO THE
MAIN BASE BEFORE USE. After the 2nd handset has charged for 16
hours, place it on the main base station for 20 seconds, it will then
automatically register and verify its security code.
Jan 27, 2008 | GE 21008GE2 Dual-Handset Cordless...
STILL SAYS "PLEASE REGISTER"
I think this may be the answer. With multiple handsets reading "Please register" and a "working" base station (w ith dial tone). If you bring the remote units to the base station and place them on hte base, they will register and stay registered after you return them to the remote base. It doesn't say this anywhere in the instructions as it gives you the impression the remotes will register from their own base.
Jan 04, 2008 | GE 25932 Cordless Phone
PLEASE REGISTER!!!!!!!!!!
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger to register.
Dec 27, 2007 | Uniden Cordless Phone
Expandable handsets lose activation:
USer manual requires,
full charge 16 hours for expandable handsets, then place in cradle ~20 seconds until 'ready' is displayed on the screen.
If power is lost the handset may have to be re-registered.
if the units are not fully charged when you register them the registration may be lost, can only suggest reversing the order, by fully charging the device then registering to see if the registration holds
Nov 12, 2006 | GE 25931EE1 Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
