Question about ICOM Informatique Icom M304 Vhf Fixed Mount Marine Radio
My SSB ICOM M801E does not switch to remote mode any more (I use a Pactor modem)
ICOM M802, can't run SEA 1612C coupler.
uk-repair.com/repair/hard-reset/icom-radio-marin-ic-ssb-m802/369/6891.html
Try this site
Oct 18, 2017 | Icom Radio Communications
No pwer output on ssb--full power all other modes
SSB power appears when you speak into the microphone
Nov 23, 2015 | Icom IC-7600 HF/6 Transceiver
Why does the unit does not seam to work on SSB?
Since everything else works then is it USB or LSB or both? Did you check the power output when your in SSB and if there isn't any you can expect the drive transistors. Try putting the radio into the RTTY or CW mode and see if there is any power output when you key the mike PTT.
Good luck,
73's Marty
Jun 19, 2014 | Icom IC-7100 Mobile radio, HF/6m/2m/70cm,...
Did you try LSB? If that works then you have problems that will have to be repaired by Icom.
73's
Marty
My ssb antenna was stollen, I NEEd another antenna for ICOM SSB model IC707, any antenna can I use to replace this, or where i can buy this antenna in the philippines
Check with ICOM on their web site or with HAM RADIO OUTLET, a large chain in North America---you may find a source that ships overseas or even one in Manilla.
Dec 14, 2012 | Televison & Video
Icom 7410 won't transmit in SSB works in CW and RTTY
I'd contact Icom, if its under warranty get it fixed
Jan 18, 2012 | Icom Radio Communications
Furuno 1552
Howdy John;
You might try going online to Ham radio outlet, they carry just about everything for ham radio. your telex kit may not be made any longer but you might be able to use a Terminal Node Controller in its place. Kantronics makes one of the best TNC's around.
Pat N5SLI
Jul 21, 2008 | Furuno FS1503 (199 Channels) 2-Way Radio
ICOM Informatique Icom M304 Vhf Fixed Mount Marine Radio Logo
54 people viewed this question
Top ICOM Informatique Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an ICOM Informatique Boating Expert? Answer questions, earn points and help others
