Question about Frigidaire FAH08ES1T Air Conditioner
Loud noise when fan is running. I think its the blower motor. any suggestions like wd40 to rid of the noise..
    Sergeant:
    Champion:
  • 311 Answers
Get a new a/c. Cannot economically fix this.
Posted on Jul 10, 2010
My toyostove laser 56 is still making a humming noise. I followed suggestions posted earlier and bearings in the blower motor were bad so I replaced the blower still getting noise, but not as loud.
Sometimes the blades on the fan itself can be out of pitch, which can cause the noise that you are writing about. You may need to replace the fan as well. It can be off just enough, that you can't really tell, but enough to make the noise.
Feb 05, 2017 | Heating & Cooling
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
Whwn i turn the heat all the way up loud clicking noise if turned lower noise stops what could this be notfan
I think your talking about the heater fan? If you hear more noise as you increase the blower speed, there is something in the squirl cage or a problem with the blower motor itself. Leaves, paper or something lite on the pass side floor, it will get sucked into the recirculation duct,causing a noise.Remove the blower motor and clean out any debris, and inspect the squirl cage and turn the motor by hand to see if you hear any noise
Sep 29, 2009 | 2005 Ford Explorer
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
York HVAC unit fan is making a lot of noise. Hot air down come out, and in the summer coll air did come out, but the fan is loud. Thanks
If your fan is making noise the blade or blower wheel is either hitting something or the bearings in the motor are bad and the motor needs to be replaced.
Oct 21, 2008 | Heating & Cooling
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Frigidaire FAH08ES1T Air Conditioner Logo
296 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
