Question about Frigidaire Washing Machines
Last load we did didn't spin at the end of the cycle. Now washer doesn't start at all. Sounds like it wants to and there's a couple of "shots" of water, but then it stops. The timer keeps counting down though.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If there is no power at all to the washer then the first thing is to check if a fuse is blown or a circuit breaker tripped, you can try to unplug it and plug it back after 3-4 minutes and see if that helps. If all this seem to be fine then it means that the Lid Switch is defective. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
  • jam0717 Jul 10, 2010
    what do you mean no power? I said it sounds like it wants to start and theres a few shots of water and the timer counts down. that means power, no?
  • Rylee Smith
    Rylee Smith Jul 10, 2010
    TO start with check the water inlet valve for any clogs and try to clean it. If its working fine then its the control board that should be replaced if not then the water inlet valve should be replaced.
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Spin cycle doesn't work...sounds like its spinning but it's not.
Does it agitate in the wash cycle?if not, you need to check the "motor coupling" on the unit. Below is a video to show you how. Here is a kink to the part.
Aug 03, 2011 | Roper RAS8445KQ Top Load Washer
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 20692 top load washer won't spin. The
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Mar 12, 2009 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
