Question about Frigidaire Dryers
Starts and runs for 20 seconds and stops...burnt odor.
    Sergeant:
    Champion:
  • 311 Answers
Motor is bad. Replace it.
Posted on Jul 10, 2010
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
Blower motor
may be motor on way out ,,,,, the resistor for the system usually allows full blower power when set to top speed,,,,
Nov 22, 2013 | 2005 Ford Focus
LT133 lawn tractor starts then stops. no spark,has gas filter ok,cleaned safety cutoff switch under seat. mower starts up,runs for 20 sec then stops.
Does the engine start up every time right when it shuts off, or will the engine not start until it's cooled off? And when the engine is running for the 20 seconds........ does it give any indication that it is going to stall, or does it abruptly shuts off with no indication of stalling? Let me know and I'll try to get back to you as soon as I can.
Oct 07, 2013 | Garden
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
20 HP Craftsman lawn tractor starts easily, but only runs
This is classic dirty gas filter ... I dont say that is all it could be ... but is it classic dirty filter. You might have something in the tank that is blocking gas getting out of the tank.
check it out ...
Oct 20, 2009 | Garden
My refrigerator has a burnt wire smell. The fans are running but the freezer doesn't seem as cold as it should be.
I'm guessing the condensor fan motor is not running. they smell like an electrical odor when they stop..remove back cover and see if something has gone into the blade area and stopped the motor from turning. if so, remove it ..if not, spin the blade and see if motor starts..if so, order new motor..you can use a floor fan to blow air towards compressor until you get a motor
Bruce
Oct 02, 2009 | Whirlpool Refrigerators
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
My dr 250 1984 has low compression
your carb got stuck and it sounds like your rings are burnt out like u were running to high of an octane or something in your gas
Mar 09, 2009 | 2001 Suzuki DR-Z 250
My Lennox Furnace starts and stops.
The reason why it stops and starts is that the sensor within the burner can not sense a flame in the furnace. The parts need to checked is the fuel filter, Air in the line, burnt out arcing rods or a bad ac high voltage transformer.
Nov 30, 2008 | Heating & Cooling
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
