Question about Motorola Televison & Video
No Signal with Motorola HD Dual Tuner DVR DCH3416
I have a Motorola HD Dual Tuner DVR DCH3416 with Mediacom Cable. It has worked fine up until recently. Whenever I turn on my tv, my receiever shows that HDMI 1 (my dvr box) is connected but when I switch to it, I get a no signal. Also the DVR box flashes constantly between 480i and 1080i resolution.
SOURCE: Motorola DVR
Try unplugging the unit for at least one minute and then plug it back in . The unit should reset itself . I will take 20-30 minutes for the guide to repopulate.
Posted on Dec 12, 2008
  • 103 Answers
SOURCE: Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Posted on Mar 22, 2007
  • 40 Answers
SOURCE: Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Posted on Apr 05, 2007
satscoop
  • 59 Answers
SOURCE: DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Posted on Dec 30, 2007
tech48
  • 624 Answers
SOURCE: Yamaha RX-V663 Not Providing 1080 Signal
First let me say that you have stated your problem very well. I completely understand the issue you are having.
I have been repairing a/v systems since they started selling them.
By your description of your problem, it is obvious that you have isolated the problem to the Yamaha.
Despite what Yamaha tech support say's, it is their problem.
I have been dealing with tech support for a lot of different manufacters for many, many years. I repair under warranty over 20 different brands, but not Yamaha. I have repaired plenty of Yamaha receivers but none with this particular problem.
It is not uncommon to find tech support people who don't know as much as they should about their own product.
Since I don't have the instruction manual or a service manual forthis model I can only be of minimal help.
What you can do, if you have your instruction manual, check it over closely for this subject on how to change the settings for the HDMI. If you can not find this particular issue, it is possible that the Yamaha doesn't support 1080i. I would be surprised if it did not, but stranger things have happened.
Another thing you can do if you can still not find an answer to this problem is to take it in to an authorized Yamaha service center.
If you have recently purchased this Yamaha, it will be under warranty. They get at least 1 year. Tell them the problem you are having and if they do not know how to solve it right there on the spot, or give you an answer that satisfies you, leave it with them
to have it fixed. If they are an authorized service center they will have to fix it or get it replaced for you if it is under warranty. It may need a firmware upgrade to the digital board. If that is the problem, then they can do it for you.
Let me know if you need any more help.
Sorry I wasn't more help, but an authorized service center may be your best bet.
Posted on Jun 26, 2008
I have no IP. How do I fix this?
I'm unsure why you think it would have an IP address on the DVR. Does it actually have a network connection jack?
The manual doesn't reveal anything about networking:
http://www.nwtel.ca/media/documents/tv/dcx3510-m_user_guide.pdf
Feb 27, 2015 | Motorola Lot Of 2 Dch-3416 Hd Dual Tuner...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
I have amotorola dual tuner dvr/ hd capable from suddenlink cable. the remote will not pull up the guide or the menu nor will it do it from the box itself. it will change the channels and i have tried...
Hi, My name is Tina and I am with Suddenlink. Are you still having this issue? If so, please feel free to email me at tina-AT-suddenlink-DOT-com for resolution.
Nov 07, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
S0900?
Poor signal. Check connections at all Coaxial connectors. Should be tightened. Unplug a/c from rear of DVR for 30 seconds. Allow time for DVR to reboot and update. Try again. If not resolved, call tech support for your cable company. May have to boost your signal.
Jul 29, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
How to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
Mar 14, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Apr 03, 2009 | Philips HTS3544/37 Theater System
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Need help setting up My Sharp Aquos LC-32D44U, also volume issue
GA293wJSA my friend gaveme this sharp tv. Nothing happens after I plugged it in I just get a blue screen what do I need to do to view a picture?
Jun 12, 2008 | Televison & Video
Televison & Video Logo
549 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
