Question about Koolatron (785169015699)
Stopped working it was plugged in the wall and was keeping my wine cold when all of a sudden, it stopped... and doesn't work anymore. What's the solution?
Not cold my mini wine fridge is not putting out cold air anymore. The lights and everything seems to be work fine
i. Carefully check your door seals for gaps / leaks.
ii. Freon or other refrigerant may be low.
iii. Compressor could be faulty.
iv. Thermostat maybe incorrectly set or faulty.
v. Somebody is drinking your cold wine and replacing with warm stock. ;)
Nov 20, 2017 | Furniture
Vauxhall Astra's remote suddenly stopped working.
Start troubleshooting by redoing the "mechanic's" work, making sure that the correct and unblown fuses are in the correct places.
May 13, 2017 | Cars & Trucks
The unit doesn't cool the wine bottles. The temp stays at 73 degrees
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 25, 2011 | Haier HVUE08A Wine Cooler
Unplugged the wine cooler to move for painting. When we re-plugged it in it was not working at all. Took off the back and cleaned out any dust from the fan. All of the wires look like they are in place....
First check your breakers. Sometimes re plugging an item can cause a surge and pop the breaker. Maybe some paint might have gotten in the outlet and preventing a clean contact. If all fails, try plugging in the unit in another outlet to see if the problem lies within the outlet or the wine cooler.
Mar 21, 2011 | Cuisinart CWC-1200 Wine Cooler
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
I have a magic chef wine cooler model mcwc16mcg justs keeping clicking not cold anymore , can this be fixed
A clicking sound every few minutes usually means the compressor is going off on overload when trying to start. This could mean the start parts are bad, or the compressor went bad.
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Power ON but unit does not get cold
I have the same issue, same thing after approx 2 years,the zone on top stopped working, even leaking water if I leave it plugged... did you ever get any answer for this?
Thx
Mar 31, 2009 | Refrigerators
Not staying cold all of a sudden
THE PROBLEM NEEDS THE ASSISTANCE OF A TECH THER MIGHT BE A PROBLEM WITH THE GAS CHARGE OR THE COMPRESSOR NOT PUMPNG EFFICANTLY.GOODLUCK. MOHAMED
Jun 22, 2008 | Danby DWC283BLS Wine Cooler
Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Koolatron (785169015699) Logo
22 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
