Question about Dryers
The dryer turns on and you can feel the heat but it won't tumble.
  • 10,319 Answers
Replace the drums drive belt along with the tensioners puley. The pulley does wear out causing the belt to break. Sears does sells these as a kit form
Posted on Jul 10, 2010
SOURCE: my candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
Posted on Mar 09, 2007
SOURCE: Dryer tumbles but doesn't heat
The next step is checking the themostats.
Posted on Apr 05, 2007
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
futureloginn
  • 734 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
RescueTech
  • 145 Answers
SOURCE: Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Posted on Dec 18, 2008
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Nov 28, 2015 | Candy Dryers
My Kenmore Elite 110.62932100 won't tumble or heat up.
try the homes 240volt circuit breaker it may not show its tripped but one of the 2 phases can trip out, (just reset the breaker) and if this happens either the dryer drum motor will turn or the timer will run, but not both as these 2 components each use 1 of the 2 phases 120 volts to run,but the heating element needs both 120volt phases for 240volts for the heating element to heat,this is what your issue sounds like to me,hope this helps
Dec 09, 2012 | Dryers
Dryer wont shut off unless turned off and dryer just tumbles with no heat.
If it won't turn off or heat then it is probably the timer or if it is a newer unit the control board.
Aug 06, 2011 | Kenmore Dryers
Kenmore dryer model 417 won't dry my clothes. It tumbles just fine but it won't get hot.
if it is electric you need a new heating element they can cost around 80 dollars for the string it yourself kind and the pre strung kit cost double that price mabye more . if you are handy i can tel you how to replace the part in detail. I have also written a few time how to replace this part if you look through my solutionshope this helps feel free to write back for more help i would love to assist you
Jun 27, 2011 | Dryers
My gas dryer won't tumble or heat
sounds like a few things are wrong/ needs checked, will not tumble is usually the belt, no heat is usually a thermal fuse if the pilot light is lit. Here is a website that will assist you Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
May 15, 2011 | Kenmore Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Dryers Logo
46 people viewed this question
Top Dryers Experts
