Question about Ryobi 3-piece 18V Drill / Circular Saw / Light Combo Tool Sets
I have ryobi 18v charger and get both yellow and green lights but bats won't charge or work at all . Time to replace bats?
  • 90 Answers
Yep
Posted on Aug 30, 2010
Ryobi 18v battery charger is not charging
If yellow and green light come on and stay on then your battery is bad if not get a new charger
Jul 22, 2014 | Ryobi 140237039 18V Ni-Cd Battery Charger
We have a Ryobi P100 Battery and a P110 charge. The battery became very hot while using it and die very fast. When trying to recharge the yellow and green light come on the charger. What is going on?
It sounds like you drained the batteries down as far as they will go. This happened to me and then I purchased the 18V Lithium-Ion battery and charger. I was able to re-charge the drained battery on the new charger. This may work for you as well. They cheapest solution for you is to just purchase a new battery.
Nov 14, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18V cordless drill the yellow and green light is on when charging what does this mean
I have found when I put a battery on to charge and the green and yellow light turn on the battery is low voltage and the charger will not charge the battery ( bad battery)
Nov 12, 2009 | Cars & Trucks
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Both green and yellow light stay on and batteries will not charge 18v
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Oct 06, 2009 | Ryobi Multi-Volt Battery Charger
Battery charge problems Ryobi 18v
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
Jan 16, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi 3-piece 18V Drill / Circular Saw / Light Combo Tool Sets Logo
255 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
JOHN LAPIER
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
