Question about Creative Labs Instant Webcam
Firewall yes the program is in the exceptions list
    Sergeant:
    Champion:
  • 333 Answers
Mmmm... then it should not be blocking it. Is this the only firewall that you have installed and are any other progs being blocked?
Posted on Apr 19, 2008
How do I remove content control on my pc
Which operating system ??..
To Remove Parental Control Software from Windows XP
Click "Start" and then open up the "Control Panel".
Click on "Add or Remove Programs".
Wait for the program list to populate. Scroll through the list and identify the monitoring web software such as NetNanny, WebWatcher or similar.
Click on the web monitoring software.
To the right of the highlighted software is a button that says "Change/Remove", or two buttons, one "Change" the other "Remove".
Click the appropriate button that will remove the web blocking software.
If you get a pop up asking if you wish to continue, click "Yes".
The Windows Add/Remove utility will proceed automatically from this point on.
To Remove Parental Control Software from Vista or Windows 7
Click "Start", then open up the "Control Panel". A new window will open up, select "Programs and Features".
The heading will now read "Uninstall or Change a Program".
Scroll through the list until you find the web blocking software you wish to remove.
Select program.
The action "Uninstall" will appear next to the word "Organize" in the bar above the program list. Select "Uninstall".
Click Yes when the message box pops up asking if you're sure you want to uninstall the parental controls program.
The uninstall utility will take over from there.
To Remove Parental Controls on a Mac
Open the "System Preferences" folder.
Select "Accounts" under the "Systems" header at the bottom of your screen.
Select the user account name from which you wish to remove parental controls from the left hand column.
Uncheck "Enable Parental Controls".
Change Firewall Settings
A firewall is a security utility designed to thwart electronic access to a network.
Firewalls are absolutely necessary because, without one, your computer is prone to being exposed to Trojans, mal-ware, spy-ware and other kinds of viral infections.
However, in some situations it is helpful to alter the firewall settings to allow certain programs to run without being blocked.
This is important to anyone whom wants to know how to access Windows Firewall and customize its settings.
Go to the start menu and select "Control Panel."
Click on the Windows Firewall icon.
It looks like a brick wall.
Choose either "On," "Block all incoming connections" or "Off" under the "General" tab.
It is recommended to have it on and not advised to turn it off.
Click the "Exceptions" tab to choose which programs you do not want to be protected by the firewall.
Click the empty box to check the programs you want to add to the list of exceptions.
It is recommended to check browsers and file-sharing programs.
Click the "Advanced" tab to choose which network connections you want the firewall to protect.
It is recommended to check all connections because your computer could be exposed to viruses if left unchecked.
Click "Restore Defaults" under the advanced tab.
This may cause some programs to stop working and is not recommended if you do not have experience working with firewall settings.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Select "Tools>Internet options" Inside Internet Explorer, then click the "Security" tab. Press the "Custom level" button.
Sep 21, 2013 | Computers & Internet
Tip
Windows XP Firewall: How to set an exception
Windows XP comes with its own firewall software, called Windows Firewall. While it's not as customizable as some other firewall programs on the market, there are quite a few things you can adjust in order to balance security with functionality. If you need to allow traffic into your network or onto your computer, you can set up an exception in the Windows Firewall to let a specific program have access, or to let communication occur on a specific port.<br /> <br /> To set up a firewall exception in Windows XP, follow the steps below.<br /> <br /> 1. Open the Control Panel (usually found on the Start menu).<br /> <br /> 2. Double click on the Windows Firewall icon.<br /> <br /> 3. When the Windows Firewall window appears, make sure the firewall is on and the box marked "<i>Don't allow exceptions</i>" is unchecked.<br /> <br /> 4. Go to the Exceptions tab.<br /> <br /> 5. If the software you want to set an exception for appears on the list of programs and services, then all you have to do is put a check next to it and click OK. Otherwise, if you want to create an exception for a program, click Add Program, and for a port, click Add Port.<br /> <br /> 6. For a program, you can either select the program you want from the list that appears, or you can click Browse to find the program on your computer. For a port, enter the name you want to call the exception (which can be just the port number if you want) and then below that type in the TCP or UDP port number. (If it is a UDP port, select UDP below the port number.)<br /> <br /> 7. Click OK to create the exception.<br /> <br /> 8. Click OK again to save the change.
on Dec 07, 2010 | Microsoft Windows XP Professional
Tip
Create Exceptions in Windows Vista Firewall
Windows Vista Firewall acts like a fence between your computer and the outer world, but since any fence needs a gate, you have to let some data get in and out by setting exceptions. While some exceptions are set up automatically by Windows Vista, others have to be configured manually Setting a manual exception for a certain program.
  1. Click Start and enter the Control Panel
  2. Here, access the link called "Allow a program through Windows Firewall" (bellow the Security). exceptions1.png
  3. Go to the General Tab, and make sure that the option "On (recommended)" is selected. If not, enable it (this will enable the firewall). exceptions2.png
  4. Go to the Exceptions tab at the top.
  5. To add a program you to your exception list click Add Program (near the bottom). exceptions3.png
  6. A list with the programs on your computer is displayed. Locate the program, highlight it and click OK. exceptions4.png
  7. Be sure that the check box besides your program is checked, then click OK exceptions5.png
Other tips
The most powerful addition to the Vista Firewall is the excellent Rules system. This allows you to enable traffic only in certain conditions, just like opening a gate only for people dressed in white, but they will only be allowed to enter.
  • to specific computers and users
  • to many different protocols (not just TCP and UDP)
  • to both local and remote ports
  • to specific interface types: location area network, remote access, or wireless
  • to specific Vista services
Despite the vulnerability claims, a well configured Vista Firewall is much more capable than all its predecessors, and despite the fact that nothing is perfect, everything starts from you, the user behind the screen.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
I want to block yahoo messenger on my computer, how can i do it?
Just block it from the Firewall settings: go to Control Panel > Windows Firewall > Exceptions and untick the mark next to it.
But the best solution is to uninstall it , from Control Panel > Programs.
Aug 13, 2011 | Computers & Internet
I can't enter free relms because i have to change my firewall settings. how do i change it so i can play it?
This will depend on what firewall software you are using. If you are using Windows Firewall, then you must go to the control panel and open the firewall settings, then add an exception. To do this, you must click the center tab, marked "Exceptions"and check the box next to the name of the program you wish to use. If you do not see your program in the list, then you can add it by clicking the "Add Program" button located below the list. This will bring up a second window with a list of installed software. If you sti9ll do not see the program listed there, then you can click "browse" and find it manually. Once you have entered the program to the exceptions list, the Windows Firewall will no longer block it's access to the internet. This process will be similar if you are using some other firewall software. Have fun gaming!
Jun 03, 2011 | Computers & Internet
I try to sign in on skype and it says, "Skype can't connect. Get help fixing this probolem."
  • If you are on a network that uses a proxy server, make sure your proxy settings are correct.
  1. In Internet Explorer: In the menu bar, click Tools > Internet Options > Connections > LAN settings.
  2. In Skype, in the menu bar click Tools > Connection options...
  • Make sure your firewall allows exceptions.
  1. If you are using Windows Firewall, click Start > Control Panel > Windows Firewall, and make sure that Don't Allow Exceptions is NOT ticked.
  2. If you are using a different firewall, click Start > All Programs and select your firewall. Make sure that exceptions are allowed. If Skype is listed in the Exceptions tab, remove it.
  3. Sign in to Skype. When prompted, select Yes to allow Skype to connect to the internet.
  • Ensure that Skype is able to use port 80 and 443 as alternatives for incoming connections.
Mar 30, 2011 | Skype IM
IM messages not going through
1) If you use Windows XP/Vista etc. firewall go to: Start > Settings > Security Center > Windows Firewall > Exceptions > Thick the "Skype" in the list, of if it isn't there click "Add Program..." > Select from the list or if it isn't there click "Browse..." > Navigate to the C:Program FilesSkypeSkype.exe (or something similar) > Ok
2) If you don't have Windows Firewall enabled, but use Antivirus/Internet Security Suite/Firewall software, go to this program, find the firewall settings and Skype to exceptions.
3) If your computer is on the work/school network, the network administrator has blocked access port to Skype - you should either ask your administrator or use Skype via this web interface: http://imo.im
Mar 05, 2011 | Skype IM
How do i unblock the firewall on my computer? im trying to sign into my windows live mesenger. but it says that i have a firewall... so how do i unblock it?
The firewall will not block the messenger unless it is out from the exceptions list or you have an anti-virus with a separate firewall..and this is blocking it ..
for to see whats on the windows firewall...go to the control panel from the start menu ..and in there you will find the firewall icon ...Double click on it ..and either disable it (not indicated cause you will be exposed to the workgroup computers..) or ...click on the exceptions...and in the list look for the windows live messenger and tick the case for to be added as an exception..After that will be ok ..
If it is not on the list ..click to add exception ..and browse for the execution of the messenger into the C /program files/windows live ..and add it to exceptions ..and also be sure it is ticked..
Oct 28, 2010 | Computers & Internet
I'm trying to download a patch for world of War craft onto my computer and it's telling me a firewall is in the way?It's stuck at 7%.
Adding a program exception
* When you add a program to the exception list, you enable the firewall to open ranges of ports that could change every time the program is run. To add a program exception, follow these steps:
* Use an administrator account to log on.
* Click Start, click Run, type wscui.cpl, and then click OK.
* In Windows Security Center, click Windows Firewall.
* On the Exceptions tab, click Add Program.
* In the list of programs, click the name of the program that you want to add, and then click OK. If the name of your program is not in the list of programs, click Browse to locate the program, and then click OK. Note If you do not know where the program is located, contact the program vendor to determine the program location.
For information about your hardware manufacturer, visit the following Web site:
http://support.microsoft.com/gp/vendors/en-us (http://support.microsoft.com/gp/vendors/en-us)
* Click OK.
* Test the program to verify that the firewall settings are correct.
PFL for your reference http://support.microsoft.com/kb/875357
Oct 12, 2010 | Computers & Internet
IPAC PDA rz1710 and Vista
If you are running ActiveSync 4.0 or later and personal firewall software on your personal computer, please add ActiveSync to the firewall program’s exception list. (Firewall software, such as Sygate Personal Firewall, TrendMicro PC-cillin Internet Security 2005, Norton Personal Firewall, McAfee Personal Firewall, or Zone Alarm Security Suite may block synchronization.) Refer to the documentation that came with your firewall program to determine how to add ActiveSync 4.0 or later to the program’s exception list. To further troubleshoot a firewall application and enable ActiveSync 4.0 or later
Jul 08, 2008 | Microsoft Windows Vista Ultimate Edition
Creative Labs Instant Webcam Logo
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
