Question about Toshiba Satellite A100-S8111TD Notebook
Want to connect laptop to tv?
I have a toshiba l-300 and want to connect it to my toshiba tv. i bought a pc to tv lead but i'm having no joy. what am i doing wrong?
    President:
  • 2,571 Answers
If you are using a LCD/TFT tv it will have HDMI and VGA inputs.
You only need a simple vga lead but this only transfers video not sound.
You can get a usb to hdmi lead, you can also plug in audio leads from your headphone socket and this will transfer video and audio.
Posted on Jul 10, 2010
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
I have a toshiba satilite latop and want to connect it to my sony bravia tv to view my photos. It has a PC socket at the back with both a one pin and a 15 pin socket. What lead do I need? and will my sony...
Normally all one has to do is use a 15pin VGA lead to connect the laptop to the TV socket, select PC on the TV and that should be that. There may be problems if your laptop in a MAC and if the resolutions do not match.
Mar 22, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Vga cable connected to tv; great picture. sound cable connected properly; no sound.
If you disconnect the 3.5 mini jack from the laptop, do you have sound? If you do you have either a lead fault or tv fault/error.
Hope that helps.
Dec 31, 2010 | Toshiba Satellite A25-S207 Notebook
Tryin to connect advent lapy to samsung tv... go to source change to hdmi3 tv sayin not connected all leads pluged in ..gone to personalization on lappy.. connect to projector or other..... tried sinc......
Try another monitor with a VGA connection and see if that works - if not you, then your output is bad in the computer or it maybe a setup issue.
Oct 27, 2010 | Computers & Internet
How to connect my toshiba satellite a205 s5804 laptop to my hd tv.vga input on tv.
you should be able to get a VGA Lead that you can plug into your laptop and the other end of the VGA cable into the VGA input on the TV
ON the TV :- Select the PC input ON the LAPTOP :- use the FN + one of the F keys, these vary by manufacture but F4 or F5 - look for a symbol of a Screen - each time you press this F+F? key, this will then toggle the out put to <Laptop><Laptop and TV out ><TV out >
Mar 20, 2010 | Toshiba Satellite A205-S5804 PC Notebook
No picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Feb 17, 2009 | Toshiba Computers & Internet
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Feb 03, 2009 | Humminbird Computers & Internet
Toshiba sat 305 s7477 shut down while on the net,will not restart
In that case have the jack checked at a good computer shop. You need to have the jack resoldered as soon as possible.
Dec 14, 2008 | Toshiba Satellite U305-S7477 Notebook
Toshiba Sattelite L20
Hi Andy,
if you have no conflicting devices, in device manager ( yellow exclamations et,c )
Theres no reason why it Should,nt Work. ( unless Theres A Fault )
have you tried toggling the fn key ( if theres one on the keyboard ) With LCD/TV Or LCD/VGA et,c.
usually located as F keys Or numerical keys on the keyboard.
Also see if theres any other settings in the Bios. F2-Esc Or Del At Start-up. Look in Video Or Display Mode.
hope this helps you out buddy.
Mike @ Compurepair.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
Toshiba Satellite A100-S8111TD Notebook Logo
180 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
