Question about LG LP1200DXR Portable Air Conditioner
My lp1200dxr has a bad motor bearing.
My lp1200dxr sounds like a bearing is going out in the evaporator blower motor. How can I get the motor out?
Howe
  • hjconner Jul 10, 2010
    I am unable to seporate the blower housing from the evaporator core.
    President:
  • 2,468 Answers
You need to split the unit at the 2 coils,its labor intensive,make sure this is the noise before ordering a new one because these fan motors are relatively expensive on these units
Posted on Jul 16, 2010
  • 532 Answers
To remove the motor from your lp1200dxr you have to cut the housing to remove the blower motor.
Your local parts house should have some tar like sealer that you can use reseal it when you are done.
Thanks for contacting Fixya.
Posted on Jul 10, 2010
  • hjconner Jul 11, 2010
    After working on it yesterday I was thinking about cutting it out but though that was a little drastic. With your advice I am willing to cut it out. Where do you suggest I make the cut to free the motor? Thank you for your advice.
    Howe
  • 6,826 Answers
If the blower motor is going out, then you might be able to replace it.
Unplug from electricity, remove screws to the panel, and investigate.
Probably, a blower motor can be replaced pretty easily by taking it apart and putting it back together.
I do not have any more information for you on this one because I have never taken this particular model apart, but have fixed conventional a/c units that had bad blower motors.
Wish you luck on this one.
  • Duane Wong
    Duane Wong Jul 10, 2010
    actually, I think that your portable a/c would be easier to fix than a conventional window a/c unit because it is so large in comparison. Which means inside it doesn't have as close clearances between parts.
    Hope this helps you out.
  • Duane Wong
    Duane Wong Jul 11, 2010
    If it is fused together then that's a problem.
    Look for any fasteners that can be undone.
    Otherwise, may have to have it serviced
    by the service center.
The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
The heater/AC makes an obnoxiously loud noise coming from the passenger side around the glove box when turned on. Has been developing for about a week.
Sounds like your blower motor bearing is going bad. Pull glovebox and you can access blower motor. Pull blower motor and check that fan/cage is tight and not clogged with leaves etc... Had an instance when mine made a bunch of noise found parking stub had been sucked into fan,
Jan 03, 2011 | Honda Civic Cars & Trucks
2004 focus 80,000 miles/6 weeks ago, using ac with blower on high, blower gradually shut off and car produced bad smell. Drove home with ac off, blower off, had car checked and nothing found. Now it's...
The 'whirring' sound from the blower motor could be a dry bearing or damaged armature (part of blower motor that the brushes ride on), or just wore brushes. The smell could be the motor winding wires burning due to blower motor bogging down and overheating. You can replace blower motor with new or salvaged one.
Dec 09, 2010 | Ford Focus Cars & Trucks
Noise in heater fan 2004 Tahoe . It sounds like a bird is in the dash
sounds like the bearings in the blower motor are going bad, try taking the motor out, ground the case of the motor and see if the sound is still there, if so replace the blower motor, sometimes a little WD40 works wonders,get back to me and let me know how you make out,we'll go from there Thanks Ray
Feb 17, 2010 | 2004 Chevrolet Tahoe
Blower is making a roaring noise and sounds like
The noise is caused from a bad or dried up bearing. You will need to replace the whole blower motor
Jan 12, 2010 | 2003 Pontiac Bonneville
Blower noisy on low speed,goes on and off intermittently.
Blower motor sounds like it is going bad and the bearings are giving you the noise. Motor going bad is the intermittent problems...bearings getting hot and motor is "reacting" to this.
Oct 18, 2009 | 2001 BMW 325
Fan on Carrier roof top ac makes loud noise on auto or high but not on low
this one is carrier AC with bad blower motor. Hope This Helps.
Sep 29, 2009 | Heating & Cooling
THE BLOWER MOTOR IS MAKING NOISES AND SMELLS
your bearing failed and is causeing friction replace motor
Jun 05, 2009 | 2001 Honda Accord
Heater blower
Sounds like the blower motor resistor is bad. These things go bad all the time. and for the switching modes there is a vacuum line that runs under the window in the engine compartment and runs by the alternator, its tiny and may take a few minutes to find. check first by the evaporator case and follow it by the alternator to the driverside of the throttle body. these too break and will not allow the heater mode changes. the blower motor resistor controls the fan speeds and the vacuum line allows which vent the air flow goes through.
Feb 09, 2009 | 2000 GMC Safari
Mastercool air conditioner
If it is indeed a true vibration, it could be a number of things. I have seen bad bearings do this off and on as the cooler runs. Could be something going wrong with the blower motor. There are several things that need to be checked to properly evaluate the problem you are describing.
Aug 29, 2008 | Mastercool 67680 Evaporative Cooler Air...
LG LP1200DXR Portable Air Conditioner Logo
63 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
