Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex salt water pump purchased 3mths ago water running threw it but cant get any display no boost no working light noithing?????? any suggestions
    Problem Solver:
  • 5 Answers
The manual says that it's fried. Sounds like something is wrong with the power supply unit. Call their 800 number and ask for a replacement. Hopefully you kept your receipt....
Posted on Jul 12, 2010
How do i set up boost cycle on modelcs8110?
This is pretty easy but first you need to realize that when you boost, the system will run 8x longer than what you have it programmed for daily... So, if you normally run it for 4 hrs per day, the boost cycle will run for 32 hrs... That's important because the filter/pump needs to be running that long plus an hour...
To begin a boost cycle, simply hold down the boost button until the BOOST Green light comes on...
Hope this helps...
Jul 01, 2014 | Intex Automatic Salt Water System for ...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I have an Intex Ultra Frame 24'x52" pool. We are installing the saltwater filtration system today. How much salt will be need to use and are there any other chemicals we should use for the initial setup?
I HAVE THE SAME POOL FOR YOUR FIRST START UP ADD 310 OF POOL SALT. IF YOU DO NOT HAVE A INTEX SALTWATER CHLORINATOR I WOULD SUGGEST GETTING ONE. IT WILL GIVE YOU READINGS ON LOW SALT, HIGH SALT, AND ALSO HAS A BOOST FOR COPPER IONIZATION, WHICH KILLS ALGEA AND BACTERIA. MIX YOUR SALT AROUND THE POOL AND LET THE PUMP CIRCULATE IT. GET A TEST KIT TO CHECK YOUR SALT LEVEL. IT SHOULD BE AT .OO3 OR 3 PPM. TO DO A GOOD JOB OF KEEPING YOUR WATER CIRCULATED YOU MAY NEED TO UPGRADE YOUR PUMP FROM THE 2500 GPM TO THE 4000 GPM PUMP. THE INITIAL SALT YOU ADD SHOULD GET YOU IN THE BALL PARK. AFTER CIRCULATING AND SWIMMING A FEW TIMES CHECK THE LEVEL AND IF TO HIGH LET OUT WATER AND ADD FRESH, IF TO LOW ADD MORE SALT. ONCE SET YOU SHOULD BE GOOD TO GO AND ENJOY FOR THE SEASON. HOWEVER I RECCOMEND CHECKING YOUR POOL LEVELS WEEKLY. HOPE THIS HELPS.
Jun 22, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Code 91
If you have hard water in your location you may want to try cleaning the electrolytic plate. I had the same issue where no matter how much salt was added I had code 91. I shut the water down going through the filter / generator. Pulled the outlet hose off and put on a cap. Pulled copper cell out and filled chamber with vinegar. Put cell back in and let set for 1 hour. Fluhed it out and hooked everything back up. Nop more salt problems. The process is in the book.
Jun 07, 2010 | Intex Automatic Salt Water System for ...
LED not working
Take it back where you bought it or call 1-800-234-6839. It has a 2 year warranty.
May 31, 2010 | Intex Automatic Salt Water System for ...
I JUST SET UP MY INTEX SALT WATER SYSTEM AFTER DISOLVING 140 LBS OF SALT IN MY 18' X 48" EASY SET POOL. AFTER ONLY RUNNING FOR 2 HOURS, IT STARTED BEEPING LOW SALT. DOES THIS SOUND RIGHT AFTER JUST...
It is possible that you do not have enough
even after disolving the salt by siring it up you need to run the filter for at least 24 hours to really disolve and mix your salt
even though you cant see it it is still not equally distributed through the water
once you have run the system for 24 hours check your salt content
It should be as close to 3000ppm as possible
a test kit will cost about 11 dollars for ten tests
Jul 22, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
237 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
