Question about Quinny Buzz Three Wheel Stroller
Back wheels keep deflating - Quinny Buzz Three Wheel Stroller
  • 4,102 Answers
Hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Posted on Jul 10, 2010
Definatly take deflated tyre to a bike shop for them to do instead of spending a fortune on new tyre!!!
Posted on Jan 21, 2011
Range Rover l322 My front air supension is iactice/inflates then deflates whilst the back remains stable
They have problems with the air bag shocks leaking. The shocks typically have a large bladder bulit into them that will over time develop leaks causing the problem you describe. could be a damaged line to the shock but most often the shock. Start the car and run until it inflates. Stop the vehicle somewhere quiet then put your head by the top of the wheel that deflates. Listen and you should head an air leak. It usually requires replacement of the shock to fix.
Dec 06, 2013 | Cars & Trucks
Where can I get replacement rear wheels for Mountain Buggy Urban pram?
check out
http://www.pushchairs.co.uk/acatalog/miscellaneous_spares.html
Dec 08, 2011 | Mountain Buggy Urban Single Stroller
My rear air bags are too high and will not deflate. The sensor is connectod ok on the rear arm. How can I deflate it manually. It is on a 1994 mark VIII
you can remove the rear lines at the air bags to deflate. most likely the problem is the air suspension control module is not turning the venting valve on to release the air from the bags.
Aug 10, 2011 | Lincoln Mark VIII Cars & Trucks
How do you remove front tire from 1999 suzuki bandit 1200
First remove the wheel, by removing the brake calipers on both sides, removing the pinch bolts from the forks and remove the wheel spindle, when wheel is removed, deflate the tyre by removing the valve core, then you will have to break the tyre away from the wheel, push down on the tyre close to the rim until it breaks the beade, repeat this on both sides of The wheel, next using some levers to remove the tyre place 1lever between the wheel just inside the tyre with the valve about 3inches to the right working away from valve place in another lever about two inches away from the other1 just inside the tyre again and push down on the lever pulling the tyre overthe wheel, keep doing this all around the wheel untill the tyre o emoved
Mar 03, 2011 | 1999 Suzuki GSF 1200 Bandit S
Wheel keeps deflating, no puncture ?!! any suggestions ?
you can buy stuff call slime check out www.buggypitstop.co.uk they have a film clip about it.
Dec 01, 2009 | Quinny Buzz Jogger
Troy-Bilt shredder model 204 tire problem.
Put a ratchet strap around the tire and tighten it up until you seat the beads enough to get some air in it and then you can fill it back up from there. hope this helps you
Oct 26, 2009 | Troy Bilt Walk Behind...
My airride on 2000 lincoln navigator will inflate but not deflate
MY 2000 LINCOLN CONT INFLATED A MONTH AGO AND WILL NOT DEFLATE. THE LIGHT COMES ON SAYING CHECK AIR RIDE SYSTEMS. HOW DO I DEFLATE?
Apr 11, 2009 | 1999 Lincoln Navigator
Problem with tires ,air is escaping
Pick up a kit for bicycle repair. Take the wheel off, deflate, pull the wheel from the rim and remove the tube. Pump the tube up a little, place under water and look for the bubbles. Once you find the bubbles, patch with the bike tire repair kit, deflate, put the tube back in, reattach tire to rim and inflate.
Apr 10, 2009 | Bertini Baby Gear
97 lincoln mark viii lower control arm.....
I am not sure if you have to deflate the air bags, but i'd assume so. First, turn off your air ride switch from inside your trunk. Then lift the front of the car in the air, make sure to lift from the frame. Next remove the wheels. To deflate the air bag here's what you do. First remove the solenoid retaining clip, located at the top of the solenoid. (It will come off with a flat head screw driver). Next turn the solenoid until it stops, (this can be counterclockwise, or clockwise depending on which side of the car your on). Once that is done, pull down on the solenoid until it stops. You should hear hissing as the air bag deflates. You can put the solenoid back in now, however i would leave it like that until you are finished replacing the lower control arm. Once your finished with the control arm, push up on the solenoid, and twist back into original position. Reinstall the retaining clip, and move to the other side of car. Hope this helps
Jul 18, 2008 | RIM BlackBerry Pearl 8100
Quinny Buzz Three Wheel Stroller Logo
368 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
