Question about Refrigerators
Hi I have a GE Profile Side by Side - model PSS23LSSASS. I came home after being away for 10 days and everything in the freezer had melted. The fridge and freezer we're not cooling. Along the back wall of the freezer there was ice and frost. I threw everything away and pulled the plug. Over the next 12 hours all the ice melted and drained. I surrounded the fridge with towels and cleaned up all the water. I plugged it back in and it seems to be cooling fine now. The freezer is around 0 degrees (f) and the fridge is right around 33 (f). I am guessing that the defrost timer or defrost heater need to be replaced. Any thoughts?
  • Refrigerators Master
  • 6,826 Answers
Yes, the defrost timer or defrost heater malfunctioned.
In your GE Profile model PSS23LSSASS, I think that it is controlled
by a computer.
Unplugging it resets it just like your computer.
Perhaps, the problem won't return and you won't have ice build up in your Frostless refrigerator.
Is your refrigerator under warranty? If it is, generally 1 year, then I would check into letting the manufacturer, in this case GE, know about your problem, so that you might get service for the refrigerator before time runs out.
Hope that helped.
Posted on Jul 10, 2010
  • 2 more comments
  • sternm Jul 10, 2010
    Thanks!
    I checked out the parts available from GE for my model and there is a defrost thermostat and heater. Do you know how/where I can access these and is there anything I can do to test to see which is bad?
  • Duane Wong
    Duane Wong Jul 10, 2010
    OK, if you want to change the heater, in my experience it requires tearing out panels on the inside to reveal the refrigerant coils.
    There probably is an exploded view of this on GE website that you saw listing the parts locations.
    good luck to you.
    The heater is just below the coils in the freezer:
    https://genet.geappliances.com/IPCNet/Di...
    Do you know of anyway to test to see if the heater is bad?
    How about testing to see if the thermostat is bad?
  • Duane Wong
    The leads to the heater can be connected to the two leads of a digital self ranging multimeter to measure the Ohms or Resistance of the heater. The specification is probably listed on the website at GE, but I don't know off hand what it is.
    I can tell you that if your refrigerator is melting the ice on the coil that builds up in the summer, that it's probably ok, and you don't have to change it.
    The thermostat can be tested in a similar way, but again the specification for ohms, I don't know that part.
    Please note that if you perform service on a refrigerator that is less than one year old, it voids the warranty.
    But, if you have it out of warranty and it does the same thing again, ice build up that is, then you may want to investigate further.
    Good luck to you on this repair.
I have a side by side GE Profile refrigerator with ice and water in door which is about 10 years old. I just noticed a thin layer of ice in the bottom of the freezer. I removed it but it returned a few...
hi look to the back of inside of freezer lower part just above where you saw ice you will see a gap that the freezer drain there a hole in the middle may be cover with ice take hair dryer and melt ice and blow out drain that should do it jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Profile temperature going up and down
One of four problems,
1: this box has two sensors in the freezer... one on the top of the evap and one on the bottom left side of freezer cabinet (little small round white things) in the back lower portion of the freezer. These have been know to go bad and cause this problem.
2: you have a defrost problem caused by a bad main board or bad defrost heater.
3: you have a evap fan going bad on you, quits when frig gets to right temps. in other words the fan doesn't like the extreme colds,
4: door gaskets are leaking air around doors.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer at 21 degrees , refer at 44 degrees, will not get any colder.
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Sep 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile PSC23. Everything works fine
I fixed it myself. After poking around the freezer, I saw that the area around the tube that gets water for ice making was frozen - this is at the top of the freezer. So I used a hot spong to melt the ice and the noise went away. Everything is working fine now.
Jun 17, 2009 | GE Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
