Question about Refrigerators
I have a Admiral Designer Series Model # hmg 521530 The problem which I have mostly fixed already is that I need a new defrost limit thermostat defrost timer and possibly a new defrost heater. I cant find a repair manual for my model fridge nor can I locate part #'s to insure they are the exact ones I need for my fridge. I have looked for a few hours but everything is giving me a guess on what part I should use. I just want to know what part to order or to pick up at Home Depo. here is the info I have; admiral Designer series serial# 1029921HF Model# HMG521530 B/M DT17A Max Amps. 7.20 R12 6. 25 El rating: 115V60HZ-100V50HZ Please help me. I would like to avoid purchasing a new fridge
aborcass
  • 2651 Answers
SOURCE: Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Posted on Oct 26, 2008
  • 219 Answers
SOURCE: admiral designer series ice maker
replace your watervalve
Posted on Mar 19, 2009
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
Sebin
  • 712 Answers
SOURCE: my admiral designer series model#HMG621860 is
Every freezer have a drip collector beneath it. Some times it may be filled completely with water thus causing an overflow. Else, the opening to the collector is being blocked by some ice. Also this problem can happen with aging of the fridge. There is nothing you can do in particular in this case.
Posted on Apr 21, 2010
  • 2006 Answers
SOURCE: I have an Admiral side by side HMG 501247
You can easily test your defrost heater with an ohm meter. And most of the time you can test it in the unit. Unplug defrost heater leads on both ends, and then put one lead of the ohm meter on one end and the other lead on the other end. The meter will show you whether you have an open circuit or not. If it is open, then you will have to replace it.
Ohm meters are very cheap under $20, and could save you money if the defrost heater is good. It is also a very good item to have for testing electrical problems in the house or car.
Posted on Jun 12, 2011
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Apr 08, 2015 | Admiral Refrigerators
I have an admiral refrigerator admiral designer series 21.1 cu ft.the motor is constanly running 8 to9 hrs at a time the left side of the door is always hot and the top of the refrigerator a repairman came...
yes compressor runs and shuts off every 8 - 10 hours for a half hour for defrost system mode. but ur hot left side may be a sign of issues needing to be addressed>
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 26, 2015 | Admiral Refrigerators
My freezer has ice and fridge does not cool. Admiral signature model HMG 19802. Any ideas
Sounds like you have a defrost problem. First thing check if you fan motor in the freezer is running. You can open the freezer door and press in the door switch and listen to the fan motor. if fan motor is running, you have a problem in the defrost system. if not, you have a bad door switch or fan motor. (not very common)
to test defrost system: Locate defrost timer (under front kick plate) and rotate slowly until you hear a click.After a few minutes you will start hearing crackling sound and see water flowing down the drain line.
if defrost is working, replace the defrost timer. if not, you either have a bad defrost heater or def. thermostat. best think is to replace both.
for more accurate instructions, we need more detailed description of problem
Feb 02, 2015 | Admiral Refrigerators
MWe have an Admiral hmg 21176 the freezer is working ok, but the bottom fridge is not. It's too warm. We unplugged it for a day and it seem to cool as always, but then returned to the warmer temp. Just...
Assuming your evaporator is completely frozen, I would defrost the coils with a hair dryer, the clip off the defrost thermostat on top of the evaporator coils. Strip and short the wires together, then check if defrost works, if so, order a new one .
Jun 22, 2011 | Admiral Refrigerators
I have an Admiral side by side HMG 501247 freezer keeps icing up and the fridge gets warm but some food like celery freezes in fridge. Replaced the defrost timer and the thermostat already and that did...
Jun 12, 2011 | Refrigerators
I have a admiral fridge designer series # HMG 62186 that I purchased in 1997. It has always had popping sounds and sparks behind the drawer in the freezer. A repairman told me this was normal, so I...
Hello WIntersno,
I understand that your refrigerator is sparking behind the freezer drawer and you would like to know if this is a fire hazard. In my opinion it would be a fire hazard as plastic and rubber is flammable and the repairman is not true in saying that this is normal. A refrigerator should never spark as this is also an electrical hazard. I would suggest having another repaid man come out and fix the problem or purchase a new box.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Admiral Refrigerators
Feezer seems like it defrosts too long and ice cubes become wet, ice cream gets very soft, then they refreeze fine. thermometer shows 25 degrees above zero when it is happening. ADMIRAL MODEL HMG 19145, 15...
well its gone wrong now? 25 degrees "above zero?" wow,,, thats cooking!!!! lets be honest,, its 15 years old? its about time you invested in a new freezer you have had your moneys worth out of this one,, and it will cost you more than its worth to fix it up, it realy is time you treeted yourself,, get a new one!
Nov 17, 2009 | Refrigerators
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1737&PPStack=1
Nov 21, 2008 | Dryers
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
