Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Robokleen stays in same spot going back and forth about four feet wont go around pool it was stuck the other day on a pool toy and couldnt get off of it we didnt know about it til we pulled it out later after that problem started first time i seen it do it i shut it off waited a while turned it on it was fine then it started doing it again. it seems like maybe getting stuck on the toy started the problem
  • 640 Answers
With these automatic pool cleaners, a jammed impeller can cause it to not work. Since the cleaner was caught on a pool toy, my guess is that it has some fabric/material jammed in the impeller and that is causing your problems. Open it up and check your impeller. I am sure that you will find it jammed.
Posted on Aug 03, 2010
I have a 2005 suzuki ferenza and wont come out of park and cant get key to go to lock position so cant get key out but i can if i unhook the battery?
This happened to me numerous times... there is a little spot by the shifter - it says "shift lock" something like that.... Push a key or something that fits in that hole and it will release. I had to drive around with a mini screwdriver forever and "unlock" that each time and one day it just stopped locking. The key also gets stuck and wont turn when the steering wheel is in the wrong position... (??) turn it back and forth as much as you can - that sometimes releases it as well.
Sep 03, 2012 | 2005 Suzuki Forenza
My robokleen won't **** anything up, impeller not plugged or stuck, just not turning, moves just fine
i thought the problem was the grease also until i seen another sales web page decription, it said NO OIL TO LEAK OUT, so i opened it up again after it shut off every day for 10 minutes of use , but still rolled
i seen the circuit board inside the air tight pump, somehow some water must have mixed with the greased part and i dried it with a cloth put it back together and it ran for about 20 minutes, then stopped, i tightend the screws as much as i could without harming the thread holes, if you break them your out of luck, did not see any seal but im sure the factory put something to keep it water proof
Jun 11, 2012 | Smartpool Dolphin Robo - Kleen Above...
Robokleen is now making very short back and forth motions not covering the entire pool as it did when first purchased
First, check the impeller for obstructions. Occasionally hair or linen may get caught in the impeller. With the transformer off, take the top grill off by removing the 2 screws from the top. If you see any debris caught, remove it and replace the grill and screws. Also, check the pool cleaners axle bearings and wheels for leaves or other debris that could be causing the wheels to catch. If you can solve the problem with either of these, you will probably have to have the cleaner services because it is going to be a mechanical issue and you will void your warranty if you open the electrical components of the cleaner.
May 13, 2011 | Smartpool Dolphin Robo - Kleen Above...
Navigator seems to do only one side of the pool. Gets stuck by the stairs,,,can't seem to back up. I have replace the rubber feet. It moves ok for a while and then will just sit in one spot for hours\...
With these pool cleaners, there are several things that you should try. First, make sure that you have proper waterflow. Too little or too much water flow into the cleaner can alter the movement and cause the cleaner to stay in one area or hang on steps. Check and clean your rear screen and make sure that you cone gear rotates both ways smoothly.If none of these seems to correct the problem, you will probably have to replace the gear box.
Sep 11, 2010 | Hayward Navigator Pool Cleaner
Stuck in a corner wont go up walls, has sufficient suction
Make sure you have enough hose (at least three to five feet past long spot in pool). Then check your baskets and filter. If you can check the impeller in the pump (If you already did this skip this part) Next remove head and take to store and have them check the diarpham and for body cracks also be sure you have checked all your hoses before going. Replace any in ?
Sep 09, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My robokleen vac runs for a few minutes then just stops. I checked the wheels nothing is stuck in there. Any suggestions?
With these pool cleaners, there are several things that you should check. Make sure that your filter bag is not full and does not have any large debris that would hinder movement. Make sure that your impeller is not jammed or broken and check the entire drive system for objects that might have become lodged.
Aug 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
Where is the fuse on the robokleen above ground pool cleaner? We've only had ours for 1 year and it stopped working. It doesn't come on at all. At first it would come on and just move back and forth in the...
There is an online manuel at this address http://74.84.137.218/website/manuals/RK01A.pdf
There is a circuit board that needs to be reset and the manuel discribes how to do this process. Make sure you are using a ground fault outlet to plug into. If there is a fuse, but I don't think there is it would be inline on the power cord. Also check the Breaker box to make sure there is power to the recepticle.
The Pool Tech
Jul 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
My robokleen is going back and forth what is wrong?
I would first check the wheels and axles bearings for hair, leaves, lint, or other debris that might be causing your pool cleaners wheels to have restricted movement. You might also want to try removing the limit screw on the wheels to see if that helps. Also, make sure that the impeller is not jammed. Remove the grill cover, check the impeller, and replace the cover. It could also be an electrical issue also. If this is the case, do not attempt to repair it. Go to SmartPool's website and find a repair service in your area.
Jun 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
ROBOT GOES BACK AND FORTH 2 FEET ONLY
There are several things to check for with these pool cleaners. First, make sure that there are not kinks or knots in the cable that would restrict movement. Make sure that there is not hair, fabric, or other debris in the impeller. This can also cause the back and forth movement. Check for debris or leaves caught in the axle bearings.
Aug 02, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
217 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
