Question about AKG K 240DF Professional Headphones
Sound went out on the right side of earphones
The sound just went out on the right side of headphones and if I wiggle it around sometimes I can get it to work it most of the time it doesn't.
    New Friend:
First, these are great sounding headphones. Comfortable too. Lightweight, good fit. NEXT: Died after about a year. They were in perfect condition, but the right channel quit on me. Determined to find out why, I dissected them, very carefully. The soft earpads can be easily slid off each side, revealing six screws. Take them out, and what you find is the tiniest, and I mean TINY TINY wires (litz wire) that Sony threads through the smallest hole you have even seen a wire go through, to get the signal from the left side, over to the right. It is through this unbelievably small hole that Sony mashed the wires when they assembled the unit, almost cutting (which is pretty hard to do, as you can't even cut this wire with a sharp scissor) the wires going through this tiny hole. Plenty of slack on the wires, but again, INSIDE the earpiece it is apparent this is a DEFECT during assembly, and no wonder, as when I finally got that wire out, I realized there is no way on earth you're ever getting it back in. Way too tight a fit. Not to worry. Just make a small hole through the outside of the left earpiece, and connect it to the wire that's going up the headset (buried in the 'over the head' band-a little hard to see, but it's in there, don't give up) and wire it to the element inside the earpiece. Actually, look at the new Sony's, and this is how they're doing it now themselves.....you can 'see' the wires on both sides of their new earphones, coming out of the headband, going into the earpieces, just like I have mine now. One last thing. you cannot 'strip' and solder this hair sized wire. To do it correctly, simple apply solder flux to the wire, and use your solder in the normal way, and the insulation will melt, and the connection will be made. Hard to believe anything is made like this, as I have headphones 50 years old that uses REAL wire, shielded, (which this wire is NOT) and they're still good. Sony tried to hide the wires in these headphones, making them kind of neat, and futuristic, but with the smallest, cheapest, hair sized wire on earth. Not a good move. They are all going to fail, and no one but YOU can fix them. No one fixes anything anymore.....but now YOU can, armed with the above knowledge. Good 'phones, crummy wire and assembly at the factory. I've seen lots of complaints about these. I like them a lot, and wanted others to know the deal.
Posted on May 02, 2014
  • 5,342 Answers
See my tip on dodgy cable/plugs on headphones.
Posted on Jul 11, 2010
How to fix coby cv320 headphones
If you hear sounds from only one earphone then most likely there is a broken wire to the earphone that is not producing a sound.
It is difficult to determine exactly where the wire is broken and repair. I suggest you get a new earphone.
Jul 12, 2012 | Audio Players & Recorders
Left ear does not work (very very weak sound)
try a regular cheap set of headphones on that device .If its the same ,then the audio device is the problem.Or try those sets of headphones on another audio device , computer,tv,cd or stereo receiver.If you are using any kind od adaptor inbetween those headphones and the audio device ,then check that..If they sound the same on any known good device..Then its possible they are bad ..let me know
Jan 03, 2008 | Shure E3C Consumer Headphones
Input jack on my hp541 kicker headphone's sound comes and goes. I have tried multiple cables, If I wiggle the cable around it works in one speaker sometimes both.
Hi hotrodjayrod,
If the symptoms remain the same after trying another headset, this kind of fault is caused by bad solder joints in the earphone jack itself of your unit. This is due to frequent inserting and pulling the headset plug. To resolve the issue, the earphone jack must be re-soldered. You have to open the back cover of your player and using a pointed soldering iron, re-solder the joints.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Kicker HP541 Headphones
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
Right headphone goes in and out
Unfortunately, you'll probably have to send the earphones to Shure for repair/replacement.
Oct 31, 2009 | Shure SE110 Consumer Headphones
Acer Aspire 1406 no sound issue
So sometimes laptops play up when the headphone socket gets a bit worn. If you wiggle a headphone jack in the socket (put it in at different angles, and rub around) sometimes the sound will come back.
There are two prongs that "detect" the headphones, and cut the speakers... and if they don't "un-contact" when the headphones are removed, the speakers stay off.
You'd need someone to solder a new headphone socket on the mainboard to properly fix it, but if you wiggle and get the speakers back, they should stay back until you use the headphone socket again.
Apr 20, 2009 | Acer Aspire 1406LC Notebook
After using the headphone jack on the side of the TV, I've removed my headphones and there is no sound. When I connect the headphones there IS sound coming from the headphones, but when there is no...
try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Apr 15, 2009 | RCA L26HD31 26 in. LCD HDTV
Earphones output is mono when plugged into a computer.
You're right - they should just plug in and work.
Some possibilities:
1. Open Volume Control on your computer - if you don't know any easier way, you'll get it from Start_All Programs_Accessories_Entertainment (in XP, at least). Once that's open, check that all the Balance sliders are in the middle of their travel.
2. See if matters improve if you fiddle with the plug - pulling it out a millimetre or two sometimes makes a difference, as can wiggling it from side to side.
3. Try other headphones on the computer - it may be that the sound card is faulty.
A.
Jan 18, 2009 | Sony Fontopia MDR-EX81LP/B Consumer...
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
AKG K 240DF Professional Headphones Logo
636 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
