Question about GPS
Hi can anyone tell mee what the problem is, i have a 2001 saab 9-3 and a fault code of p1231, any help would be great, many thanks
  • 10,515 Answers
1231 relates to potentiometer sensor 1 reading incorrectly and causes idle and surging problems. It happens because the throttle plate begins making brief closing motions.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
Hi my Saab 2001 93 2.0 turbo convertible has lost power get into limp home mode I reset it every few weeks codes come up p1105 p1260 p1251 p 1264 what do u think is wrong ?
code p1105 refers to manifold absolute pressure(MAP) sensor, TC system-leak detected. causes ---intake leak, ---hoses There are to references to p1105 The second response is still map sensor but the causes are---TC system--mechanical fault--air leak between throttle body-TC,map sensor---TC system--exhaust blockage
code p1260 refers to throttle return spring--weak spring force. causes ---mechanical fault,--,throttle control unit
code p1264 refers to throttle valve opening-accelerator released causes ---throttle control unit---mechanical fault
Mar 28, 2013 | 2001 Saab 9-3
I have saab 9-3 1.9tid 05 fault code 1125. can anyone tell me what this is?
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
fuel is getting to hot ,this is a renault engine and in the fuel filter is a temperature sensor i think which could be faulty or take the fancy plastic cover off the engine so the air can circulate better
May 19, 2012 | 2008 Saab 9-3
What do I need to fix my 2002 saab 9-5 2.3t with fault code p1108?
The definition for fault code P1108 for your Saab is:
Charge air absolute pressure sensor circuit - short to B+.
This sensor is located on left pipe connection of charge air cooler.
Either you have a bad sensor or a short in the wiring and/or plug leading to the sensor. Hope this helps.
Regards
Louis (Macanac)
Oct 24, 2011 | 2002 Saab 9-5
I retrieved codes 1260 1251 and 1231 with a snap on versus. it will not give me any code descriptions. will not idle on own. vehicle seems to misfire will holding throttle to keep running. after i clear...
CODE P1260 THROTTLE RETURN SPRING WEAK SPRING FORCE. CODE P1251 THROTTLE POSITION MOTOR FULLY CLOSED POSITION. CODE P1231 THROTTLE POSITION SENSOR 1 AND 2 RANGE PERFORMANCE PROBLEM. SOUND LIKE PROBLEM IS MECHANICAL PROBLEM.YOU HAVE WEAK THROTTLE RETURN SPRING.GO TO DEALERSHIP PARTS DEPARTMENT FOR NEW RETURN SPRING.
Jan 15, 2011 | 2000 Saab 9-3 Viggen
2001 Saab 9-5 SE It will be running great and
Change crankshaft position sensor,located on a back side of the engine block next to the gearbox on a front side.
Apr 05, 2010 | 2008 Saab 9-5
My 2003 SAAB 9-3 check engine light and transmission light came on giving codes PO741 torque converter CKT performance or stuck off and PO743 torque converter circuit electrical what does this mean
unfortunately this means you need to get yourself to a trusted transmission repair facility very quick. the torque convertor on your vehicle is not operating the way it should. this is going to be an expensive repair, i tell you this so your not suprised. but do your homework and find someone with a great reputation for their work. dont take your saab to just anyone. these cars can get really screwed up without the right people workin on it. the transmission will need to come out.
Jan 06, 2010 | 2001 Saab 9-3
Turning off service light on saab 93
Hi,If you press and hold the reset button on the SID unit the message will go out ,however it might come back on a few times so you may have to repeat this for a couple of days till it stays out.
Jan 29, 2009 | 2001 Saab 9-3
GPS Logo
56 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
