Question about Kenmore 57029 Side by Side Refrigerator
No ice in maker
The ice maker has worked fine for three years. Now there is no ice being made. There doesn't seem to be a clog in the water line and we are able to get water through the door fine. There is a red light that blinks, but nothing else is happening. There is no ice in the tray either. It's almost like it dropped it's last load of ice and just stopped working.
  • Kenmore Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingno ice in maker - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
Built-in side by side. The in-freezer ice maker is not working properly. makes one row of ice every 10-2 hours. i have checked temp, water filter and water line...all is fine. had the ice maker replaced...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kitchen Ranges
Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
heatman101
Jun 08, 2010 | U-Line Icemaker
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water wont go all the way into the ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
No ice from ice maker
sounds like the inlet valve is defective. you should have a dual water inlet valve, one side for the dispencer and the other for the ice maker. I would check to be sure the inlet for the icemaker is not clogged, also check to be sure that ice has not clogged the water line near the ice maker, or the valve could be defective.
Feb 20, 2009 | Frigidaire Refrigerators
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
98 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
